Author Topic: What type of keycaps are these? (Fits onto Topre!)  (Read 6192 times)
Offline Sniping
« on: Sat, 20 July 2013, 14:11:13 »
I just bought an old electronic typewriter at a garage sale this morning and I'm not sure what kind of keycaps these are. I may try to see if I can fit some of these onto my Topre with some shaving, but the caps look pretty thick so I'm curious as to what these are made of.
« Last Edit: Sun, 21 July 2013, 14:13:01 by Sniping »
Re: What type of keycaps are these?
« Reply #1 on: Sat, 20 July 2013, 14:15:01 »
You can test them a couple of different ways to see what they are: http://imgur.com/a/fAi8I
I'd guess ABS, but I could be wrong.  As for what they are, I'm sure it's some proprietary cap mount.
Offline bazemk1979
« Reply #2 on: Sat, 20 July 2013, 14:26:53 »
some awesome quality caps there, they don't make them like this anymore....
« Reply #3 on: Sat, 20 July 2013, 17:16:22 »
Since it's tripleshot, I would strongly suspect ABS
Nice find, there aren't too many known tripleshot keycaps out there.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Sat, 20 July 2013, 17:34:28 »
Can we see the other sides? Maybe they would be cool on a Topre, in which case you could send them here...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Sat, 20 July 2013, 18:03:46 »
I've never seen a stem like that. It kinda looks like topre, but I doubt it is
Offline Sniping
« Reply #6 on: Sun, 21 July 2013, 00:35:54 »
The stem is actually very similar to Topre, and if there was a cut on the top of the stem as well as the bottom, then it should fit with a Topre because the switches these caps came off of also have the stem of the keycap on the inside like Topre, and are similar in size as well. The profiling on the keycaps are also very odd because they're semi-low profile but look like they should fit OK if they were put on a Topre board. Here's a picture of the front of the caps, I put the enter key in that picture because the back of it looks pretty crazy.
Edit: You can't really see it in the picture but the green stem on the enter key is twice the height of the cap.
Offline Sniping
Re: What type of keycaps are these? (Fits onto Topre!)
« Reply #7 on: Sun, 21 July 2013, 14:32:13 »
So, another update. I tried cutting the stems of two keys (The "1" key and "," key) and I ended up screwing both those stems up for keyboard science. The shape looked right but when I put it on the board it was waaaay too loose. Then, right AFTER, I found out that these caps just fit right onto my Leopold FC660C without any modification at all.   Like I said in the previous post, these caps were semi-low profile, but they actually don't really look shorter than the stock keycaps. The biggest thing though is the feel with these keycaps, these caps give it a VERY tactile feel. They feel stiffer than stock keycaps and the bump is accentuated. At the very top of the switch you can notice that these are a whole lot stiffer than stock caps, and the bump is more pronounced, and I think this is due to the profile of the keycaps. The caps have slightly varied heights, but it looks like this is caused by inconsistencies in the stems of the Topre stem itself. My "h" and "," caps are lower than the rest of the keycaps on my particular board, and at first I was getting a repeating key for both those letters, but I adjusted the fit of the "h" key and it seems to work perfectly now, though I still sometimes get a repeating key with "," but for normal use (Pressing it once, and not trying purposely to get the key to repeat) it seems to do just fine. I wouldn't say that these caps make the board thock more, because it's probably just placebo, but the extra tactility and bump is definitely not.
« Reply #8 on: Sun, 21 July 2013, 14:33:23 »
Oh wow. Easily the best topre keycaps you can get. Triple shots..
Any idea what kinds of switches the typewriter uses?
Offline Sniping
« Reply #9 on: Sun, 21 July 2013, 14:38:14 »
Wait for it....wait for it....
rubber dome
Offline jil_jil32
  • Tokyo Press <3
« Reply #10 on: Sun, 21 July 2013, 14:59:34 »
Oh hahah, nice keys you got there :3
Offline insilica
  • Keyboard Geeza
« Reply #11 on: Mon, 22 July 2013, 07:53:42 »
I don't think they will fit on the Topre, Topre caps have a little catch on them, or if they do they will be loose as hell.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline esoomenona
  • Gnillort?
« Reply #12 on: Mon, 22 July 2013, 08:21:16 »
How much do you want for those!? Or can you point me in the direction of where they came from? I LOVE ABS caps, and that looks like Cherry font. Would be amazing on a Topre board, to try to remind me that I belong to Cherry MY, even if I'm slumming it on other switches.
Offline Sniping
« Reply #13 on: Mon, 22 July 2013, 08:52:29 »
I'm planning to auction these off in a few day to raise some money so I can get an ErgoDox eventually.
@insilica These fit pretty well on Topre considering they weren't even made for Topre switches.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #14 on: Mon, 22 July 2013, 08:54:23 »
What brand of typewriter was it? Model would be nice too :))
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Sniping
« Reply #15 on: Mon, 22 July 2013, 08:55:44 »
Brother AX26, I couldn't find anything about it on the interwebz though.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #16 on: Mon, 22 July 2013, 09:01:46 »
Yeah, all I could find was ribbon cartridges :/
TOO BAD FOR YOU
« Reply #17 on: Mon, 22 July 2013, 09:27:32 »
I didn't try too hard or too long but I concur...
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #18 on: Mon, 22 July 2013, 09:28:28 »
Guess it's time to bug every eBay seller to take a cap off and send me a pic :))
TOO BAD FOR YOU
« Reply #19 on: Mon, 22 July 2013, 09:40:40 »
I've learned you'd be surprised what some sellers will do, you might even get lucky.
Offline insilica
  • Keyboard Geeza
« Reply #20 on: Mon, 22 July 2013, 14:01:01 »
How very interesting. Will keep an eye for these on fleabay or if they should show their faces on the classifieds  :))
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #21 on: Mon, 22 July 2013, 14:07:25 »
So Topre doubleshots actually technically exist!!? Awesome!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #22 on: Mon, 22 July 2013, 14:09:19 »
They're technically not Topre, but they fit! And they're actually tripleshots!
TOO BAD FOR YOU
Offline Alessandro
« Reply #23 on: Mon, 22 July 2013, 15:56:58 »
I've waited my whole life for this! Now I just need a Realforce. :p
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #24 on: Mon, 22 July 2013, 16:41:26 »
Your life isn't complete until you own at least 3x Topre's!
TOO BAD FOR YOU
Offline RabRhee
« Reply #25 on: Mon, 22 July 2013, 16:58:44 »
Couldn't find much on the AX-26 either, but I see there are a lot of models, AX-20, 25, etc.
this one looks to have similar keys, for starters
http://www.ebay.com/itm/Vintage-Brother-AX-20-Word-Spell-Dictionary-Electronic-Typewriter-Tested-Working-/380655894142?pt=Vintage_Electronics_R2&hash=item58a0dbfe7e
-Life is good-          Crafting: |  KeychainsMore.   .Keychains | Crowdsource Key | Budget Keycap Board |
