Author Topic: Difference in blue switches  (Read 2538 times)
Offline oppz197
  • Hai there
« on: Tue, 23 July 2013, 20:36:37 »
So today I bought a birthday gift (Razer Black Widow with blue switches)for my brother  :cool: I tried to type on it afterwards and comparing to my QFR blues it feels different...
I know they are both blue switches but why?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Difference in blue switches
« Reply #1 on: Tue, 23 July 2013, 20:41:01 »
Full size vs tenkeyless, different plate material (aluminum vs steel), different keycaps, different batch of switches, assembly differences, overall quality of materials differences...
Offline oppz197
  • Hai there
« Reply #2 on: Tue, 23 July 2013, 20:45:03 »
I feel like the typing experience with QFR is much higher quality
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #3 on: Tue, 23 July 2013, 20:46:00 »
Man, you're a bad brother. :))
Makes sense...
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline oppz197
  • Hai there
« Reply #4 on: Tue, 23 July 2013, 20:50:18 »
 :-[ :-[ I type on it after he opened it
Offline Photoelectric
« Reply #5 on: Tue, 23 July 2013, 20:50:30 »
I would also expect a Costar-made QFR to feel better than a RBW, given the general consensus here that Razer mechanicals are of inferior quality.
Offline oppz197
  • Hai there
« Reply #6 on: Tue, 23 July 2013, 21:01:26 »
Btw which of the material is best for keycaps abs pbt pom?
« Reply #7 on: Tue, 23 July 2013, 21:31:13 »
The verdict is that it's down to personal preferences.  You will find people who like each of those kinds of plastic for their keycaps, and then different profiles and thicknesses.  Durability-wise, in terms of developing shine, it's PBT > POM > ABS.  Otherwise, you may have to experiment yourself to find what you prefer.
Offline oppz197
  • Hai there
« Reply #8 on: Tue, 23 July 2013, 21:33:39 »
Whats the difference between those 3 btw u know what kind of caps does qfr uses?
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #9 on: Tue, 23 July 2013, 21:42:29 »
QFR is ABS.
« Reply #10 on: Tue, 23 July 2013, 21:43:14 »
QFR uses ABS, as does the Razer keyboard.
Here's something you may find interesting for different keycap materials for Blue switches:
http://geekhack.org/index.php?topic=42133.msg903796
You can read about different keycap materials here:
http://deskthority.net/wiki/Main_Page
Offline Xenderwind
« Reply #11 on: Tue, 23 July 2013, 21:43:20 »
QFR has abs
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline oppz197
  • Hai there
« Reply #12 on: Tue, 23 July 2013, 22:12:26 »
Thanks for your info man :D
« Reply #13 on: Wed, 24 July 2013, 11:49:26 »
Razer or iOne in general use ABS on standard, but the backlight caps I think are made of nylon.
« Last Edit: Wed, 24 July 2013, 11:51:28 by IvanIvanovich »
« Reply #14 on: Wed, 24 July 2013, 11:51:48 »
Razer use ABS on standard, but the backlight caps I think are made of nylon.
That's what I've been wondering about--same for Ducky Shine and CM Storm backlit caps.  They say "ABS" in descriptions,  but they feel very different from normal ABS and are quite soft vs thin doubleshot ABS--when bending the sides.  I figured it was some sort of special ABS that's  translucent and is correspondingly softer, then coated in whatever color to be impenetrable for LED light.
