Author Topic: Cheap Soldering Gear  (Read 2416 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« on: Fri, 26 July 2013, 13:19:43 »
First up is a Hakko FX888 that usually retails around $100, on sale for $80. (EDIT: Appears it's just the 888, not the newer 888D. It's an analog temp change system vs a digital one. Discontinued model. Exact same pen and heating element AFAIK, just a different interface.)
http://www.all-spec.com/products/FX-888.html
Next is a nice 1lb spool of Kester 44 .031" 63/37 for ~$22
http://www.all-spec.com/products/KW4410.html
Only downside to this site is a minimum purchase of $25 is required or you incur a ~$9 fee.
« Last Edit: Fri, 26 July 2013, 13:26:27 by oTurtlez »
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline alaricljs
  • I be WOT'ing all day...
Re: Cheap Soldering Gear
« Reply #1 on: Fri, 26 July 2013, 13:56:40 »
Unfortunately after shipping it's only a couple bucks cheaper than the 888D on Amazon (if you aren't paying for Amazon shipping).  On the other hand, I prefer the analog version, so if I needed it this wouldn't be too shabby.
Filco w/ Imsto thick PBT
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Fri, 26 July 2013, 14:02:00 »
Shipping only went up a dollar or two once I added the Solder and a Soldapullt. Viable option if you're going to be combining an order :) Do you think I should go Analog or Digital for the 888?
TOO BAD FOR YOU
Offline alaricljs
« Reply #3 on: Fri, 26 July 2013, 14:05:28 »
I like the quick and easy adjustment of grabbing the knob.  There are presets for the 888D, but personally, nothing beats a quick tweak of a knob.
I could say it again if you want :)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Fri, 26 July 2013, 14:09:23 »
It's too bad the nonD isn't available anymore other than maybe secondhand.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #5 on: Fri, 26 July 2013, 14:10:51 »
Thanks for the opinion :) The Digital one looks weird anyway, only has a temp up button? I like the ease and simplicity of a knob. Looks like I'll be ordering it to(day)(night) :p
This is the nonD :)
TOO BAD FOR YOU
Offline alaricljs
« Reply #6 on: Fri, 26 July 2013, 14:17:38 »
Yeah the temp adjustment is a digit modifier... like setting a digital alarm clock.  You select a digit and press up until it's the number you want.    blech!!!
