Author Topic: Where can I buy LEDs for MX Switch/Poker?  (Read 7964 times)
Offline pixel5
    • pixel5
« on: Tue, 30 July 2013, 09:11:15 »
I've searched every term I can think of and I can't find what I'm looking for...
I need red, white, and blue LED's for my Poker II. I have no idea what size/voltage/etc to buy, or where to buy them. I need like, 'the idiots link to LEDs'. Any help is appreciated!
Poker II
Quickfire Rapid
BUY MY CRAP
Offline esoomenona
  • Gnillort?
Re: Where can I buy LEDs for MX Switch/Poker?
« Reply #1 on: Tue, 30 July 2013, 09:15:53 »
You can buy them on eBay. Most people have been suggesting the 2x3x4mm flat LEDs lately. The voltage thing might be a bit more difficult. I'll let someone else answer that for you...
« Reply #2 on: Tue, 30 July 2013, 09:23:08 »
These have been recommended in the past but I've never used them...yet...
http://www.ebay.com/itm/320999089508?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Offline pixel5
    • pixel5
« Reply #3 on: Tue, 30 July 2013, 09:29:52 »
Hmm, wonder if there is a good place where I can pick them up in lower quantities...don't wanna spend $20 for 300 extra LEDs i'll never use.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline JPG
  • Model F is my new passion!
« Reply #4 on: Tue, 30 July 2013, 09:36:26 »
For me this link is 7$ for 100 leds
« Reply #5 on: Tue, 30 July 2013, 09:37:41 »
^^ yes this is what I linked ;)
how many do you want and how much do you want to pay?
Offline pixel5
    • pixel5
« Reply #8 on: Tue, 30 July 2013, 09:47:23 »
Cause he wants 3 colours
http://www.ebay.com/itm/10pcs-2x3x4mm-WHITE-Water-Clear-LED-Lamps-With-12v-Free-Resistors-234W-amy-/321089670304?pt=LH_DefaultDomain_0&hash=item4ac26f8ca0
http://www.ebay.com/itm/10pcs-2x3x4mm-BLUE-Water-Clear-LED-Lamps-With-12v-Free-Resistors-234B-amy-/330889452668?pt=LH_DefaultDomain_0&hash=item4d0a8c5c7c
these are 10 quantities each order
http://www.ebay.com/itm/100pcs-2x3x4mm-Rectangle-Red-Water-Clear-LED-Light-Leds-/221138055543?pt=LH_DefaultDomain_0&hash=item337cdaf177
reds are $5 for 100 pcs..
so you need 2x10 blue + 2x10 white + 100 red = $13 for all.
You, my friend, are brilliant.
Not sure how I feel about the flat/rectangular ones, seeing as how the fittings on the switches are round...but if that's what everyone is recommending there must be a reason for it.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline Tarzan
  • formerly known as Greystoke
« Reply #9 on: Tue, 30 July 2013, 09:49:00 »
I'm pretty sure that LED profile is best for keycap clearance.  I still need to get some of these myself, in green.
« Reply #10 on: Tue, 30 July 2013, 09:49:26 »
The problem with the round ones is some keycaps hit them and the solution is to slightly file on the LEDs.
Offline pixel5
    • pixel5
« Reply #11 on: Tue, 30 July 2013, 09:54:06 »
Alright, anyone else use these themselves? Just looking for confirmation.
Other than that, are there any GOOD (read: correct) videos out there showing how to solder on the typical PCB? I 'know' how, but a visual would help. This is gonna be a fun project!
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #12 on: Tue, 30 July 2013, 09:56:52 »
have a look at any of WFD videos they should help
Offline elton5354
« Reply #13 on: Tue, 30 July 2013, 09:57:08 »
I use these LEDs for all my boards.
Whitefiredragon makes tutorial videos on this kinda stuff.
http://www.youtube.com/user/WhiteFireDragon/videos
« Last Edit: Tue, 30 July 2013, 09:58:54 by elton5354 »
Offline pixel5
    • pixel5
« Reply #14 on: Tue, 30 July 2013, 10:01:43 »
Hot. thanks again!
Poker II
Quickfire Rapid
BUY MY CRAP
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #15 on: Tue, 30 July 2013, 11:16:51 »
2x3x4mm work well
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #16 on: Wed, 31 July 2013, 16:05:13 »
I'm thinking about having these modded onto my board: http://www.ebay.com/itm/100pcs-2x3x4mm-2x3x4-mm-Rectangle-White-Diffused-LED-Leds-Lamp-Free-Resistors-/321161076422?pt=LH_DefaultDomain_0&hash=item4ac6b11ec6
It says: "This is for 100pcs 2x3x4mm Rectangle White Diffused LED Leds Bulb Light Lamp + 100pcs 1/4W 470ohm Resistors"
Will those resistors work for our keyboards?
Offline pixel5
    • pixel5
« Reply #17 on: Tue, 13 August 2013, 13:46:47 »
Alright, so I've ordered the LEDs... I'm curious about how to remove the solder thats already on the board. I don't have one of those special vacuum tools. Is it possible to use the solder thats already there to solder the LEDs in?
Poker II
Quickfire Rapid
BUY MY CRAP
Offline JonasDK
  • Let me poo on you
« Reply #18 on: Tue, 13 August 2013, 14:18:16 »
I don't think you can do that.
Offline Broadmonkey
« Reply #19 on: Thu, 15 August 2013, 16:26:53 »
No, unless you can heat both holes at the same time, and then you would still need some solder, because there is a high possibility that the existing solder won't create a good connection.
I use a solder sucker that I bought for €2 and it has so far desoldered more than 450 swithces including LEDs or diodes. You would need one of those at a minimum. Some say that you can use solder wick, but it really is a pain to use and not even worth buying for these kind of projects.
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #20 on: Sat, 17 August 2013, 22:17:25 »
This is the exact info I was looking for. Bought a pack of 100 for 7 bucks shipped.
Awesome.
I don't actually have a PCB to put these in yet, but hey, that'll come.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline turtle
« Reply #21 on: Wed, 04 September 2013, 09:24:01 »
Exactly what I was looking for. Sweet.
