Author Topic: [disregard] cherry model g81-1800  (Read 2434 times)
Offline wellington1869
« on: Tue, 21 October 2008, 16:38:20 »
hi all - looking for a Cherry keyboard (black color) model g81-1800 (originally came with black cherry switches, i believe). (see pic below). This is the non-trackball/trackpad compact (spacesaver) with numberpad on the right. If you have one, if you can pull off a keycap, I'd love to know (or have a pic) showing how the switch is mounted (if the two side tabs are visible so you can dismantle the switch and swap the stem?). (as in these pics: )
A shot in the dark I know, but thought it might be worth a try! ;) Thanks!
using: ms 7000/Das 3
does anyone have a black g81-1800 keyboard?
« Reply #1 on: Tue, 21 October 2008, 17:13:46 »
ER - never mind. I dont need the g81 - it has MY switches which i cant use.
um, how do you delete a thread? ;)
