Author Topic: Jumpers on 122 key Model F  (Read 1169 times)
Offline h2gofast
« on: Thu, 01 August 2013, 08:07:58 »
Do the jumpers on an old 122 key model F have any current usefulness.  I have a couple and this is the only one with the jumpers, or do the others just have them inside. the case?
Re: Jumpers on 122 key Model F
« Reply #1 on: Thu, 01 August 2013, 09:05:05 »
One or two of the ones I bought came with the DIP switches. I disconnected them but kept them in place because they look cool.
On one of my earliest conversions I messed around with a single jumper on the controller (I believe I discussed this in my guide) but after that the later ones seemed to work properly without any fuss. Perhaps Soarer refined his software to accommodate more variations.
« Reply #2 on: Thu, 01 August 2013, 09:23:56 »
My 6110668 has jumpers and works well with soarer's teensy converter. I have disconnected the jumpers.
I believe they are used to set the keyboard ID.
Offline h2gofast
« Reply #3 on: Thu, 01 August 2013, 14:30:01 »
Thanks,
I haven't moved any of the jumper's.  Set the way they currently are the board works with Soarer's converter.  The extra ting on the keys does seem to annoy the dog though.  :)
