Author Topic: red black switch spring question  (Read 1684 times)
Offline jonathanyu
« on: Wed, 07 August 2013, 12:04:26 »
What is the g of red switch spring measure in Korea? is 50g or 55?  :rolleyes:
If 62g spring compare to original black spring, which will be heavier?
Offline Vintage
Re: red black switch spring question
« Reply #1 on: Wed, 07 August 2013, 12:06:50 »
I believe a red spring is 60g in terms of Korean springs.
MX black springs are about 80g so they are significantly heavier than 62g Korean springs. The 62g are closer to Red springs.
CM QFR w/ MX Reds  | Logitech G900
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Wed, 07 August 2013, 12:11:07 »
They're more or less a 59 - 60g spring. The 62g's are a bit heavier than "light" springs, and the closest comparable to a stock black spring is an 80g.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline jonathanyu
« Reply #3 on: Wed, 07 August 2013, 12:13:26 »
so 45, 50,and 55g spring will be lighter than red?
« Reply #4 on: Wed, 07 August 2013, 12:14:39 »
yes
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #5 on: Wed, 07 August 2013, 12:15:19 »
Much
TOO BAD FOR YOU
Offline jonathanyu
« Reply #6 on: Wed, 07 August 2013, 12:41:45 »
 ;) thank you!
« Reply #7 on: Wed, 07 August 2013, 13:17:28 »
For future reference check this out: http://geekhack.org/index.php?topic=46449.0
Korean springs measure at bottom out, Cherry measures at actuation. Rkinze measures at both :P
Offline jonathanyu
« Reply #8 on: Wed, 07 August 2013, 17:31:56 »
Great  :D
that show every kind of spring!
