Author Topic: Dye-subbed, or printed? How to tell the difference?  (Read 3268 times)
Offline davkol
  •  Post Editing Timeout
« on: Thu, 08 August 2013, 04:57:40 »
The title says it all. How to tell, whether keycaps are dye-subbed, or high-quality pad-printed?
I've tried to scratch the keycap, but lettering wasn't damaged. There might be some sort of coating though.
Re: Dye-subbed, or printed? How to tell the difference?
« Reply #1 on: Thu, 08 August 2013, 05:54:34 »
If they're pad printed, the letters will be *slightly* raised and you should be able to feel the difference. It's been very obvious on my 700R and Filco MJ2 caps.
Offline davkol
« Reply #2 on: Thu, 08 August 2013, 06:07:10 »
I can't feel it, that's why I'm asking.
Offline MKULTRA
  • telling it how it is
« Reply #3 on: Thu, 08 August 2013, 06:10:37 »
Post pics?
Offline phx
« Reply #4 on: Thu, 08 August 2013, 09:25:54 »
if you can't feel it then it's dye sub.
a lot of modern rubber domes are dye sub I think.
« Reply #5 on: Thu, 08 August 2013, 09:28:01 »
Sounds like it might be dye-sub. But on my 700R, I know they're pad printed and then there's a coating/sticker applied. So it feels smooth but they're pad printed.
Offline phx
« Reply #6 on: Thu, 08 August 2013, 09:59:52 »
well.... the sure way to tell is to cut one in half  :))
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7 on: Fri, 09 August 2013, 14:31:58 »
Another way to tell is to hold the cap up so you can catch a reflection off the legend.  While moving it around slightly if you catch a very shiny spot only if a very close proximity to the legend than it is pad printed.  I believe the reason for this is in the printing process.  If my theory is correct it comes from the heat of the ink in the machine that puts the legends on and essentially polish's the area right next to the legend.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Fri, 09 August 2013, 14:35:56 »
It's because they add a UV coating over the pad printing to add durability to the printing process.
Offline Melvang
« Reply #9 on: Fri, 09 August 2013, 14:36:19 »
Thats right i stand corrected
« Reply #10 on: Sat, 10 August 2013, 03:48:32 »
Some pictures of this would be nice, if anyone has any.
Offline Melvang
« Reply #11 on: Sat, 10 August 2013, 06:58:14 »
Trying to catch that shiny spot around the legend might be a little on the difficult side
« Reply #12 on: Sat, 10 August 2013, 07:11:39 »
What about asking Dianoda?
His macro photos are fantastic!  See here.
