Author Topic: Not sure what this keyboard is???  (Read 6176 times)
Offline do_Og@n
« on: Sun, 11 August 2013, 00:10:52 »
Here is the ebay link:
http://www.ebay.com/itm/PRAVETZ-MECHANICAL-ATXT-BULGARIAN-KEYBOARD-1988-GOOD-CONDITION-/181186089441
I don't know what type of switch it is but the keycaps look like they are compatible with Cherry MX switches.
Who's brave enough to find out?  ;)
Offline do_Og@n
Offline Rule16
  • R.I.P. SmallFry
Re: Not sure what this keyboard is???
« Reply #2 on: Sun, 11 August 2013, 00:17:42 »
Looks like a rubber dome with cherry style caps.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline daerid
    • Rossipedia
« Reply #3 on: Sun, 11 August 2013, 00:44:28 »
Did someone say [Thunderfury, Blessed Blade of the Windseeker]?
(sorry, had to)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #4 on: Sun, 11 August 2013, 07:02:19 »
I think you'd call that "buckling rubber sleeve" — it's like a rubber dome, but it's hollow and sits around the slider. Various keyboards used it, as a way to offer a tactile sensation, with the Mitsumi hybrid switch being the most notable for it. (The buckling rubber sleeve tends to replace the normal coil spring.)
If you increase the brightness on the switch photo on the second auction page, you'll see that the switch is circular! Never seen that before. I've heard of Pravetz, but I've not seen the switches they used. You can see the circular shape more clearly here:
http://www.ebay.com/itm/PRAVETZ-MECHANICAL-AT-XT-BULGARIAN-KEYBOARD-1988-/181192361760
Bore Awards
Offline do_Og@n
« Reply #5 on: Sun, 11 August 2013, 17:21:47 »
I think it's funny how I've been watching Ebay for almost two years and this is the first time I've seen these boards come up.
Interested in the keycaps but not for $75+
Offline AGmurdercore
« Reply #6 on: Sun, 11 August 2013, 18:15:09 »
FML i never ever expected that we used to make mechanical kboards in Bulgaria :O
What the hell am I even doing
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #7 on: Sun, 11 August 2013, 20:06:40 »
I KNOW WHAT KIND OF KEYBOARD IT IS...IT'S AN OVERPRICED KEYBOARD! I WOULDN'T PAY $75 FOR AN OLD RUBBER DOME JUNKER LIKE THAT WHEN I'VE ALREADY GOT 20 OF THEM HANGING AROUND IN MY BASEMENT.
  • RIP
    • Boring twaddle
« Reply #8 on: Mon, 12 August 2013, 14:39:05 »
I CAN'T HEAR YOU, COULD YOU SPEAK UP A BIT?
Bore Awards
Offline do_Og@n
« Reply #9 on: Mon, 12 August 2013, 15:23:35 »
Can someone please send that man a keyboard with the caps lock disabled and shift+alpha keys disable?
« Reply #10 on: Mon, 12 August 2013, 17:00:06 »
It's ok - he's stuck using DOS with only uppercase words and maximum 8 characters.
Offline Rule16
  • R.I.P. SmallFry
« Reply #11 on: Mon, 12 August 2013, 19:03:45 »
(sorry, had to)
did he said [Thunderfury, Blessed Blade of the Windseeker]?
Dvorak Only Zone
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #12 on: Mon, 12 August 2013, 20:37:32 »
(sorry, had to)
I heard [Thunderfury, Blessed Blade of the Windseeker]!
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline jacobolus
« Reply #13 on: Tue, 14 January 2014, 08:47:16 »
Here’s another Pravetz. This one looks like it might have a different kind of switch though? Looks interesting.
http://www.ebay.com/itm/181236033985
« Reply #14 on: Tue, 14 January 2014, 08:53:52 »
50872-1
« Reply #15 on: Tue, 14 January 2014, 08:57:00 »
Hall effect? If it is...
Offline BlueBär
« Reply #16 on: Tue, 14 January 2014, 11:40:41 »
Very interesting, each switch is held down by a screw! The Alps Magnetic Reed switch is similar with that corner "cut" off, but the ones Haata found are not mounted with screws. They also have some markings on top of each switch, this one doesn't seem to have that.
Offline BlueBär
« Reply #17 on: Tue, 14 January 2014, 17:11:50 »
Whatever it is, it's mine now. If it's decent I'll convert it with a Teensy.
Offline do_Og@n
« Reply #18 on: Tue, 14 January 2014, 21:57:20 »
LOL....surprised to see this thread reopened. Let us know what you think of it.
« Reply #19 on: Tue, 14 January 2014, 23:13:07 »
There appear to be 2 stabilizing pins and 2 contacts per switch. Stem is closer to vintage SMK than most hall effects I've seen. It's likely a russian clone of something.
The switches individually screwed down is a cool thing to see: you get it sometimes on microswitch keyboards without plates (they are much less common though).
Very interested to see more pictures / info on this! Glad you got it bluebar
Offline BlueBär
« Reply #20 on: Wed, 15 January 2014, 03:14:51 »
I sent Haata a message and he said that it could be a variation of a switch he has and that he's pretty sure that it's a soviet magnetic reed switch, which means it could be a clone of the Alps Magnetic Reed switch I mentioned.
I will definately document the disassembly, I'm quite curious what kind of switch it will be.
Offline jacobolus
« Reply #21 on: Wed, 15 January 2014, 18:36:32 »
Here’s yet another Pravetz keyboard. This one looks to have a similar type of cross-mount, but an added rubber thingy, cylindrical caps [a bunch missing], and a different layout. [Like the original posts from upthread, but with slightly better pictures.]
http://www.ebay.com/itm/141165021481
Edit: oh, there are even nicer pictures at http://geekhack.org/index.php?topic=48700 .. nevermind. :)
« Last Edit: Wed, 15 January 2014, 18:46:40 by jacobolus »
