Author Topic: [IC] Poker 2 and CNC 60% Cases . Simple black case 50 USD  (Read 34374 times)
Offline Photoelectric
Re: [IC] Poker 2 and CNC 60% Cases . Simple black case 50 USD
« Reply #50 on: Fri, 16 August 2013, 17:20:37 »
That's a safe assumption as well!
Offline Neal
  • Skype: iNewbcake
« Reply #51 on: Fri, 16 August 2013, 18:27:51 »
What are these cases made of? I heard someone say it isn't aluminium?
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #52 on: Fri, 16 August 2013, 18:50:48 »
Looks like Aluminium, not sure yet though.
Offline codyeatworld
« Reply #53 on: Fri, 16 August 2013, 18:57:19 »
I'd be in for one or two!
Offline 4814
« Reply #54 on: Fri, 16 August 2013, 19:01:24 »
Interested! But I really want to see it with a plate, too ;)
Offline Rafen
« Reply #55 on: Fri, 16 August 2013, 19:43:17 »
I would be very interested if I could get one of the blue ones.
Offline Cottonsox
« Reply #56 on: Fri, 16 August 2013, 19:56:53 »
Interested, will be keeping an eye on this!
Offline oneproduct
  • @Ubisoft
« Reply #57 on: Sat, 17 August 2013, 00:04:58 »
Assuming the $50 cases are the same as the fat front lipped ones in terms of height, there's already one picture of them with a plate in the albums he linked:
Layout: Colemak
Offline LechnerDE
« Reply #58 on: Sat, 17 August 2013, 03:08:03 »
If it's really that cheap, I'll probably fall for a blue one although I don't need it at all :D
Offline JonasDK
  • Let me poo on you
« Reply #59 on: Sat, 17 August 2013, 05:24:12 »
Definitely interested!
Offline pexon
    • Pexon PCs
« Reply #60 on: Sat, 17 August 2013, 06:02:41 »
Nothing back yet, will most likely be monday now.
Offline JonasDK
  • Let me poo on you
« Reply #61 on: Sat, 17 August 2013, 07:04:45 »
Excited, can't wait!
« Last Edit: Sat, 17 August 2013, 12:52:10 by JonasDK »
Offline Qipz
« Reply #62 on: Sat, 17 August 2013, 07:47:39 »
I see that these cases are really flat, doesnt that type weirdly when your keys are tilted backwards?
I mean, I always used those feet on every keyboard ever so the keys are sloping down towards me.
Offline pr1me
« Reply #63 on: Sun, 18 August 2013, 09:46:05 »
Quick question: This will be a group buy or for sale on PexonPcs ?
« Reply #64 on: Sun, 18 August 2013, 09:49:44 »
I believe this will just be sold through pexon.
Offline fydo
  • Meow!
« Reply #65 on: Sun, 18 August 2013, 10:11:12 »
In the pictures, it appears there are circular indentations on the bottom of the CNC case. If they're not already included I'd imagine one could just get some rubber feet and stick them on.
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline pexon
    • Pexon PCs
« Reply #66 on: Sun, 18 August 2013, 12:05:41 »
Not sure yet, but the price will be the same regardless.
Offline Dubsgalore
« Reply #67 on: Sun, 18 August 2013, 13:46:06 »
pexon bro, i think ill be in for one when they go up
Offline pexon
    • Pexon PCs
« Reply #68 on: Sun, 18 August 2013, 14:57:14 »
OK man, thanks for letting me know. Seems as though there is a good amount of interest. I will see if I can sort something out to get the ball rolling this week.
Offline pix3l_fodder
« Reply #69 on: Sun, 18 August 2013, 16:04:30 »
+1 for a cheap case
Offline gnubag
« Reply #70 on: Sun, 18 August 2013, 17:21:51 »
i am in for 2.
will there be a choice for the color or only black?
Offline electrogeek007
« Reply #71 on: Mon, 19 August 2013, 02:53:04 »
These are GH60-compatible, correct? If so, in for one of these, definitely the blue one if it was made available.  :thumb:
Offline pexon
    • Pexon PCs
« Reply #72 on: Mon, 19 August 2013, 04:01:45 »
i am in for 2.
For the cheap one, its black only I believe.
Offline Qipz
« Reply #73 on: Mon, 19 August 2013, 04:20:45 »
you linked 2 imgur links, isd there
Offline Qipz
« Reply #74 on: Mon, 19 August 2013, 04:21:55 »
those 2 imgur links, which one is which? also, the cheap one will work with the gh60 right?
Offline pexon
    • Pexon PCs
« Reply #75 on: Mon, 19 August 2013, 04:28:06 »
These are the cheaper ones... The imgur links are the more expensive ones.
Offline Qipz
« Reply #76 on: Mon, 19 August 2013, 05:11:05 »
what makes them so cheap?
Offline pexon
    • Pexon PCs
« Reply #77 on: Mon, 19 August 2013, 05:21:23 »
Perhaps they are from offcuts and they are just using up spare material? The quality should be fine, a metal case will always better than stock anyway!
Offline Qipz
« Reply #78 on: Mon, 19 August 2013, 05:33:51 »
Ofcourse! and I'm very interested in this one, as for the feet, does it come with some feet or will it just rest on its back?
« Reply #79 on: Mon, 19 August 2013, 08:45:50 »
so long as it fits I think that would be just fine!!
Offline pexon
    • Pexon PCs
« Reply #80 on: Mon, 19 August 2013, 09:27:51 »
OK cool. Well I am frantically finishing orders this week, need to get them all out before Thursday as I have LAN over the weekend. Hopefully I will know more by then and I can get a GB rocking sometime next week.
Offline LechnerDE
« Reply #81 on: Mon, 19 August 2013, 09:29:01 »
Sounds good :)
Offline vorn
« Reply #82 on: Mon, 19 August 2013, 09:49:14 »
I'm definitely keen on one of the new lipped cases!!
Offline AtL
« Reply #83 on: Tue, 20 August 2013, 10:07:28 »
I would go for one case and a custom usb cable to save money from shipping.
« Last Edit: Tue, 20 August 2013, 10:21:33 by AtL »
KBC Poker ♣
Offline Qipz
« Reply #84 on: Tue, 20 August 2013, 11:35:50 »
that's actually a fantastic idea, I'll get the same
Offline pexon
    • Pexon PCs
« Reply #85 on: Tue, 20 August 2013, 18:10:14 »
I'm going to be running a special offer when I get these in, along with the Poker 2. You can buy the poker and cable or all 3 (case too) for a discount  ;)
Offline vorn
« Reply #86 on: Wed, 21 August 2013, 00:46:16 »
Nice!!!
Offline LechnerDE
« Reply #87 on: Wed, 21 August 2013, 01:13:52 »
You know how to make my wallet bleed :D
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #88 on: Wed, 21 August 2013, 04:18:01 »
I can get some Poker 2 boards in soon, just need to gauge interest and what type of switches.
I may also be able to get in some CNC cases in 60% flavour.
I would like a cnc case  :))
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #89 on: Wed, 21 August 2013, 09:09:24 »
It would appear that these cases are being made by/for Tex.
grey-case-02 by 反光鏡的視野, on Flickr
More here
« Reply #90 on: Wed, 21 August 2013, 09:11:26 »
More here
This is interesting considering the recent comments about something else coming from  tex 'soon'.
Offline tricheboars
  • Keyboards are Important!
« Reply #91 on: Wed, 21 August 2013, 10:25:23 »
i have the iMav low profile vortex case on my plated poker. the case and plate come together perfect, almost flush. it's straight money tanks awesome.
my case looks just like the ones pictured except it is just aluminum and silver.
Offline Qipz
« Reply #92 on: Wed, 21 August 2013, 11:02:15 »
care to explain further?
Offline vorn
« Reply #93 on: Wed, 21 August 2013, 11:14:21 »
Well Tex just released photos of this exact CNC case on their Facebook page. Speculation over :)
« Reply #94 on: Wed, 21 August 2013, 13:19:57 »
Maybe 1 month , We will show new keyboard to you guys :)
Offline Dubsgalore
« Reply #95 on: Wed, 21 August 2013, 23:53:38 »
can we get any colors other then black? would rather a red or grey for my poker
More here
i think they are slightly different, look at the bottom side, seems to be fatter on the TEX one
Offline whiskytango
  • Don't touch the trim
« Reply #96 on: Thu, 22 August 2013, 11:22:01 »
With a little more info, obviously, I would be in for at least 2 of the simple black $50 cases, assuming you figure out how to ship US for less than an astronomical figure :)
Offline JonasDK
  • Let me poo on you
« Reply #97 on: Thu, 22 August 2013, 14:16:36 »
Any news on this?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #98 on: Fri, 23 August 2013, 00:09:23 »
I'd like to ask if it would fit all 60% ? Poker II for example ? :D
Offline gnubag
« Reply #99 on: Fri, 23 August 2013, 00:13:39 »
have you seen the title?
also I don't think that the poker 2 is a 60% keyboard.
