Author Topic: Bueller's 66-key Custom (inspired by Matt3o)  (Read 4833 times)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« on: Sat, 17 August 2013, 00:28:15 »
Will do a more detailed write up on the steps I took to get to this stage but I'm not 100% finished yet so I'll just start with some pictures!
Still need to get some caps on her as well but I have a tiny bit of soldering left and I'm also waiting on a 7U space bar + 1.5x mods to arrive.
« Last Edit: Sat, 17 August 2013, 00:34:46 by bueller »
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
Re: Bueller's 66-key Custom (inspired by Matt3o)
« Reply #1 on: Sat, 17 August 2013, 00:55:43 »
Nice work! I love the layout. What controller is that?
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline JPG
  • Model F is my new passion!
« Reply #2 on: Sat, 17 August 2013, 01:07:30 »
Very nice job!
Offline bueller
  • MX baller
« Reply #3 on: Sat, 17 August 2013, 01:07:58 »
http://www.mattairtech.com/index.php/development-boards/atmega32u4-usb-development-board-arduino-compatible.html
Bought it so I could wire a USB port directly to the controller but it's a little bit too large to be worth it really.
Offline bueller
  • MX baller
« Reply #4 on: Sat, 17 August 2013, 01:53:13 »
Looks like I may need to resolder the micro-controller or I have completely fubared it and will need to replace. The = key just keeps repeating again and again even after desoldering that entire column :(
Got a Teensy breakout coming from Melvang so I may just go with a Teensy 2.0 to save the hassles.
Offline domoaligato
« Reply #5 on: Sat, 17 August 2013, 01:58:10 »
are you sure that maybe you don't have something fubar'd in the firmware? I ran across this with hasu's firmware because I messed up my layout.
Offline bueller
  • MX baller
« Reply #6 on: Sat, 17 August 2013, 02:24:20 »
That's not a bad idea, might resolder the 2 columns I've pulled off and take another look at the firmware.
« Reply #7 on: Sat, 17 August 2013, 08:01:45 »
I like it! Keyboard science in action.
Offline UniClown
« Reply #8 on: Sat, 17 August 2013, 19:20:49 »
This is truly great! I've sort of been following your project from a distance because I plan on making my own 65% board at some point in the future. That wiring is pretty insane and must have taken a lot of work. Congrats on getting this far. I bet you're super excited to finally put some caps on dat.  :thumb:
Edit: also, what is your function layer configuration? You already gave me this as your layout.
« Last Edit: Sat, 17 August 2013, 21:44:09 by UniClown »
Offline bueller
  • MX baller
« Reply #9 on: Sat, 17 August 2013, 22:10:25 »
Yep  that's my layout! Definitely took me a long time to get the wiring done, next board is going to have a PCB I think as I don't want to go through that again. Just need to speak with samwisekoi and see if there is anything I can do to push the GH65-75 project moving :)
Can't wait to get some caps on it, just waiting on a CCnG set :)
Offline UniClown
« Reply #10 on: Sun, 18 August 2013, 11:01:08 »
Yeah, I'd probably wait for that project to finish because the PCB is top-notch. I think you misunderstood my question. I know your layout. However, I am curious as to what your function layer is aka what do your keys do when you hold down function key.
Offline JPG
« Reply #11 on: Sun, 18 August 2013, 11:25:51 »
Hey, I am considering getting a similar case done, but I have no experience with any cnc machine. How much did it cost to make a case like that and what kind of file is required?
Offline bueller
  • MX baller
« Reply #12 on: Sun, 18 August 2013, 12:15:15 »
Ah of course, my function layer is pretty simple really. The numeric keys are all F1-F12 and the arrows are pgup/dn and home/end.
The cost for all the material and cutting was $66 and all you need is a CAD file. I'll try and post mine up in the next couple of days.
« Reply #13 on: Tue, 20 August 2013, 14:08:19 »
Looking great so far!  Love the progress you've made.  :D
Offline rurushu
« Reply #14 on: Fri, 23 August 2013, 14:47:35 »
wow... this thing must weigh quite alot... considering so many pieces of raw metal wedged together!
