Author Topic: FlashGet G600 MX Cherry Blacks  (Read 35079 times)
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« on: Mon, 19 August 2013, 12:49:50 »
EDIT: Let me state that I was asked to review this keyboard gy geekTH a banggood.com rep and was compensated with a coupon code for the keyboard.
I would also like to state that this compensation does not alter my review on the keyboard itself.
Okay! This is going to be my first major post here on GeekHack. This is a reivew of the FlashGet G600 MX Cherry Black.
32341-0
Table of Contents
Order and Shipping
I ordered this FlashGet G600 from BangGood.com which distributes from China. They offer worldwide free shipping(main reason I decided to order). Total shipping time was only 14 days, I cannot complain about 2 weeks free shipping overseas. The package was shipped very well and no damage was done to the keyboard or box for that matter. The only thing I would change would be to have it shipped in a box instead of the keyboards manufacturer box wrapped in soft foam and then put into a watertight shipping sleeve.
Shipping Score
: 8/10
32353-1
First Impressions
My first impressions of the keyboard was that it looked nice. It is technically a plate mounted board but the base is the plate. It is much like the Corsair K series in that matter. It had a nice weight to it. Typing on it felt very hard due to the MX Blacks ( I am a Blue kind of guy). Switch type is a preference though. I did not care for the logo. The contents of the box where as follows:
Keyboard with red key caps installed
Full set of black key caps
Detachable Micro USB cable(non-braided)
User Manual(Chinese)
Mini-CD to install programming software
Base and Keys
The base, it is metal over plastic like the Corsair K series boards. It has a metallic finish to the metal. I say that because it is not just brushed metal. The base has 3 cable channels. Has 5 rubber feet plus the feet are wrapped so when extended they also have a grip. The side profile is a slight upward line (a little more if using the feet).
Base Score:10/10 (for the price)
32343-232355-332357-4
The Key caps are standard ABS plastic one set translucent red and the other solid black. The legends appear to be lasered on and do have a slight rough filling to them. The stabilizers are costar. The F1 - F12 key also function as media keys. The switches are standard MX Blacks (not much to say here). They feel heavy to me even after using them for over 3 weeks at work. I want my blues back :( . But again switches are a preference but, I do not recommend Blacks for typing/Coding all day. Since the keys are ABS they will start to shine but I did not notice anything to would make me assume they will shine any faster than my WASD key caps.
Key Cap Score: 7/10 (two sets included)
32345-5
Extended Use Impressions
After using the keyboard for over 3 weeks(3 weeks at work, 1 at home). I can safely say that the keyboard is very well built for a sub $100 USD keyboard. Plus it does have a metal base/plate. The legend font is a very streamlined font, many straight lines. Font is also a preference for me. I like the font you may not :) . I do like that the black set of key caps has windows Caps Lock, Scroll Lock and the Print Screen key(Windows key lock). The board is very quiet to type on and I am sure co-workers at the office appreciate that very much compared to my normal Blue board. There is a slight ping echo when typing sometimes but that could be just how I type. The board does not move at all thanks to the grips even when using the feet. All keys are responsive when typing. Since it is a TKL board transporting it to and from work has been a breeze. Not having a keypad is taking some getting used to but I do like that my mouse is much closer to my other hand especially when gaming. Since the base is the plate there is no extra plastic trim so the board is small even for a TKL. If I liked Blacks I could see me using this bored at work permanently.
I was first drawn to this board do to the fact that is had a metal top base which reminded me of a Korean custom (this is not a custom by any means) but to my non-keyboard enthusiasts at work I will never tell :) . I still like the metal base very much and the media keys are very nice as well. Using the software provided you can customize your layout, more on that in the next section.
Software
The provided software allows you to remap any key to any single key.(i.e. A -> H) and store them on up to 5 different profiles. The Insert-Home cluster can be set to use macros. Finally, it also allows your to change the polling Rate, Manually set the Windows Key On/Off, the response time and the LED light intensity. I have not done to much with the software though.
Software Score: 9/10 (lots of features, made for gamers)
32347-632349-732351-8
Conclusion
To wrap things up, I have say that I really do enjoy the FlashGet G600, it is my second keyboard after a WASD V1 with Blues. The price is very nice at ~85 USD at least from BangGood.com, not sure of other retailers. Its solid construction and programability as well as two keycap sets. The partial metal base and smaller form factor. I would recommend this board to anyone who wants a metal base look at a much lower cost and likes heavy switches(they do have  Cherry Red version as well).
This seems to be a keyboard gears towards gaming and I would have to say that for gaming (FPS for sure) it would be a wonderful keyboard.
The Pros: Price, Partial Metal Base, Two Key cap Sets, Programmability and Free Shipping.
The Cons: Key caps (ABS), Non-Braided USB Cable, Longer Shipping Time, Possible ping sound when typing.
Overall Score: 8/10 within its price range.
Thank you for reading my first review here on Geekhack I hope to have more in the future as I acquire more keyboards and more in depth reviews as well the more I learn about keyboards in general.
« Last Edit: Wed, 11 September 2013, 12:27:28 by ITzNybble »
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Re: FlashGet G600 MX Cherry Blacks
« Reply #1 on: Mon, 19 August 2013, 13:00:06 »
Good write up! Thanks for sharing your experience. I for one am always wondering how reliable some of these not so common website are as well as these not so common keyboards!!
Offline ITzNybble
« Reply #2 on: Mon, 19 August 2013, 13:03:08 »
Agree with you 100% that's why I really wanted to get this review out. A while ago I mentioned I may buy this board and most of the common responses were, "never heard of it. If you buy it let me know how it is".
Thanks for the kind words as well :)
Offline herbyscrub
« Reply #3 on: Tue, 20 August 2013, 18:11:34 »
Thanks for the review.  I really do like the metal plate look myself and was considering this keyboard for a while.
« Reply #4 on: Tue, 20 August 2013, 18:22:03 »
Thanks for that - great writeup, very well organised.
Interesting for a "metal" board with a full set of transparent keycaps - good price too.
This would look wicked with red backlighting ;)
Offline ITzNybble
« Reply #5 on: Tue, 20 August 2013, 19:29:29 »
Thanks I took my time learning some BBCode to do it :). If only there was a backlit version *drool*
Offline PadawanGeek
« Reply #6 on: Wed, 21 August 2013, 00:08:34 »
Aw damn, so tempted, it's going for 78USD right now.......and I prefer Cherry Black too. Gonna mentally masturbate over this...
Offline HotKillerZzz
  • Ammesia
« Reply #7 on: Fri, 06 September 2013, 06:22:52 »
Is there a backlights?
Offline ITzNybble
« Reply #8 on: Fri, 06 September 2013, 07:13:25 »
Only on caps lock scroll lock and the print screen(windows lock)
Offline ITzNybble
« Reply #9 on: Fri, 06 September 2013, 07:14:12 »
I'm selling mine for 60 + shipping. I just do not care for blacks.
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #10 on: Fri, 06 September 2013, 15:36:16 »
It is quite a nice looking board, thanks for posting.
Offline PadawanGeek
« Reply #11 on: Fri, 06 September 2013, 21:07:08 »
I'm in Asia, shipping cost would prolly make it not viable.....
Offline ITzNybble
« Reply #12 on: Sat, 07 September 2013, 01:59:45 »
Most likely yes :(  Well if anyone in the US/ Canada wants it check out my WTB thread in the classifieds :)
Offline LechnerDE
« Reply #13 on: Mon, 09 September 2013, 05:51:53 »
Thanks for the review!
A couple of quick questions:
1. Is this a standard spacebar or does it have odd stem postions like the Leopold Keyboards?
2. Is the Logo above the arrow keys printed? Or is it a sticker? Could you rub it off without damaging the case itself? I think it's kinda ugly and I would prefer the case without it.
Offline ITzNybble
« Reply #14 on: Mon, 09 September 2013, 08:57:03 »
1. Standard spacebar, it uses costar stabilizers. No odd stem positions.
2. it is printed on but just took a push pin and lightly brushed he side of it and i just fell off so i went ahead and removed it, gives it a much cleaner look.
34730-0
Offline LechnerDE
« Reply #15 on: Mon, 09 September 2013, 09:26:36 »
Thanks for the fast reply!
This board gets better and better. I am really thinking about ordering one - if it only had blue switches  :p
Offline acer589
  • Gotta get out of college
« Reply #16 on: Tue, 10 September 2013, 23:17:41 »
Man, I really do not like those keycaps. Luckily, those are the easiest  things to replace.
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
« Reply #17 on: Tue, 10 September 2013, 23:21:18 »
It is an unusual keyboard.  Occasionally I am tempted to buy something like this for the shock value at work.
Offline skuko
« Reply #18 on: Wed, 11 September 2013, 03:47:46 »
i'm tempted to order this just for the sake of checking it out, since it comes in red switch flavor.
BUT, i'd love to see someone take it apart first, to see if the switches could be replaced without soldering - from all pictures i saw, there's no solder on the plate itself, so they "could" be PCB mounted, which could mean a non-soldering replacement possibility.
it does look good though :)
and btw, for waht i can tell, those stabs are not costar, they're cherry, amirite?
Offline skuko
« Reply #19 on: Wed, 11 September 2013, 06:50:15 »
would you mind opening it up for the sake of board inspection? :)
nevermind, i checked classifieds and saw you already sold it.
« Last Edit: Wed, 11 September 2013, 06:53:08 by skuko »
Offline ITzNybble
« Reply #20 on: Wed, 11 September 2013, 07:15:59 »
Yup, but they are costar stabs and you would have to solder to remove the switches or open them
Offline skuko
« Reply #21 on: Wed, 11 September 2013, 07:38:17 »
thanks for the reply man :)
Offline ITzNybble
« Reply #22 on: Wed, 11 September 2013, 09:16:18 »
Never a problem...I have been on these forums for a while know and have started to make an effort to respond and aid the community more. :D. This forums is truly a great place.
Offline BakerMan1971
« Reply #23 on: Thu, 12 September 2013, 07:00:10 »
very flash get that is :)
screaming for a couple of custom keycaps here and there, it definitely looks a better deal than the PLU I purchased.
« Reply #24 on: Thu, 12 September 2013, 18:03:44 »
I see what you did there.
« Reply #25 on: Fri, 13 September 2013, 05:54:19 »
I suppose my main point is I went for the PLU from the same site, I kind of expected it to be a bit more glowy even without backlighting, and my see-through keycaps are not to the liking of a few of my friends, however had I been furnished with another full set of caps then it would have been more impressive.
The keyboard is still going strong however :) and I am wondering if I can actually introduce some LED's to the inside top place for some illumination.
Offline Yarden
« Reply #26 on: Fri, 04 October 2013, 08:18:56 »
I have the same keyboard but with red switches, and i have a small question:
How did you change the language in the software? the deafult one is chinese..
Offline ITzNybble
« Reply #27 on: Fri, 04 October 2013, 09:12:53 »
when you install the software you select chinese or english I believe, you must have just hit "ok" like 5 times like most users do when installing stuff :). Try reinstalling the software.
Offline Yarden
« Reply #28 on: Fri, 04 October 2013, 10:14:55 »
Indeed! thanks.
Offline ITzNybble
« Reply #29 on: Fri, 04 October 2013, 10:40:31 »
not a problem, your welcome
Indeed! thanks.
Offline Yarden
« Reply #30 on: Fri, 04 October 2013, 12:45:05 »
Well, now i have another porblem with the software..
The changes i make dont show up in the keyboard..
I.E: I set the light intensity to 0 yet the caps lock is still lit when i press it.. i did press apply/ok after the change and nothing changed.
Have you experienced something similar?
Offline MTManiac
« Reply #31 on: Fri, 04 October 2013, 12:51:21 »
definitely a much cleaner look!
good review, I saw this a while back and was interested
Offline Zeal
    • Zeal Generation Inc.
« Reply #32 on: Fri, 04 October 2013, 13:10:55 »
Nice review. I saw this keyboard about a month ago, but wasn't too sure about the metallic finish on it. It looks like it was spray painted on?
Offline ITzNybble
« Reply #33 on: Fri, 04 October 2013, 15:38:40 »
it does seem ot be painted on in some manner maybe not spray paint but nothing like a nice anodized custom case.
Offline ITzNybble
« Reply #34 on: Fri, 04 October 2013, 15:39:06 »
Offline Mysticode
« Reply #35 on: Tue, 08 October 2013, 18:49:04 »
Still selling this keyboard? I have not tried any mechanical keys before, but I read Blacks are similar to the resistance in membrane dome keyboards?
« Reply #36 on: Tue, 08 October 2013, 20:23:37 »
MX reds are closer to rubber dome.
Blacks are much stiffer (maybe like a really worn rubber dome, but much, much smoother).
Offline gh_pp
« Reply #37 on: Tue, 08 October 2013, 21:26:55 »
Software
Very nice review. I’m especially impressed by the key mapping capability of a consumer grade keyboard.
Can I ask for a little test? Can the software map [ to {, and { to [
i.e. without holding the shift key, [ key will output { and vice versa.
If that is possible, it would be an ideal keyboard for programmers since {} are used a lot more often than [].
Thanks
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline synerr
« Reply #38 on: Thu, 12 December 2013, 06:37:01 »
So I went ahead and got a G600 as I wanted an affordable keyboard I could take apart and play with.  Here are some pictures of what greeted me on removing the underside:
The PCB
47760-0
Controller:
47762-1
Solder close up:
47764-2
Press any key to continue, any other key to quit.
Offline PadawanGeek
« Reply #39 on: Thu, 12 December 2013, 07:30:12 »
Good god, what a mess! :eek:
Offline Linkbane
« Reply #40 on: Thu, 12 December 2013, 08:53:28 »
Mother of god.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline ITzNybble
« Reply #41 on: Thu, 12 December 2013, 09:07:43 »
Whoa! well that would explain the price :P....Thanks for show this. This might help someone decide if they want it or not.
Offline tgujay
« Reply #42 on: Thu, 12 December 2013, 09:15:33 »
The PCB
Controller:
Solder close up:
Holes for LED's!  does the software support lighting?
Gotta collect them all
Offline ITzNybble
« Reply #43 on: Thu, 12 December 2013, 09:18:29 »
The PCB
Controller:
Solder close up:
Well there are LEDs on a few keys...so technically you should be able to add your own...might need some additional set up though, resistors and such...
Offline synerr
« Reply #44 on: Thu, 12 December 2013, 09:31:35 »
In all fairness the white stuff is just solder flux but you would not expect that to be handed over like that in a final product.
Offline ITzNybble
« Reply #45 on: Thu, 12 December 2013, 09:40:47 »
I agree it looks worse than it really is, but I do feel flux should be cleaned up a little bit more than that before production release :)
Offline tgujay
« Reply #46 on: Thu, 12 December 2013, 09:50:50 »
The PCB
Controller:
Solder close up:
Usually on boards where there are only LED's on the mods like the Quickfire there are no LED through holes for the rest of the switches on the PCB, in that picture there are LED through holes for all of the switches.  This leads to believe this board uses the same PCB as a backlit model, like the Poker 2, and there are probably hot keys for adjusting the LED's once installed.  The D numbers next to the switches are for the diodes, I'm assuming the L numbers are for the corresponding resistors for LED's.
« Last Edit: Thu, 12 December 2013, 09:52:33 by tgujay »
Offline osi
« Reply #47 on: Thu, 12 December 2013, 09:52:36 »
Interesting board. Thanks for sharing.
Offline ITzNybble
« Reply #48 on: Thu, 12 December 2013, 10:07:22 »
The PCB
Controller:
Solder close up:
I concur with your thoughts!
Offline tgujay
« Reply #49 on: Thu, 12 December 2013, 10:14:22 »
The PCB
Controller:
Solder close up:
If you still have your board after the new year I will take it off your hands, I quite like Blacks and don't have any TKL(Phantom project put on hold for time and money) right now.
