Author Topic: How to clean keyboard with rubber-like material  (Read 2764 times)
Offline gunbuster363
« on: Tue, 20 August 2013, 01:37:39 »
My new keyboard ( cm quickfire xt ) have a case with rubber-like material. Any safe liquid to clean it? I think alcohol is a no.
I just clean some stain with a piece of disinfectant wet tissue with the following ingredients: chlorhexidine 0.1%, Aloe Vera, Glycerine.
P.S. I have a bad experience cleaning my deathadder mouse several years ago when it had covered with dust. I tried to clean it with 75% rubbing alcohol and the rubber material on the mouse was damaged.
Re: How to clean keyboard with rubber-like material
« Reply #1 on: Tue, 20 August 2013, 12:36:50 »
Can't ever go wrong with popping the shell off and cleaning it with warm soapy water.
« Reply #2 on: Tue, 20 August 2013, 12:41:24 »
I usually use a wet wipe, denture tabs, warm soapy water, or rubbing alcohol at like 20% concentration.
Offline Quardah
    • DeliTech
« Reply #3 on: Tue, 20 August 2013, 13:45:24 »
Turn it upside down over bird
Shake
It's raining food
It will love you from now on
Keyboard is clean
Nothing left on floor.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline trrc
« Reply #4 on: Tue, 20 August 2013, 13:59:57 »
Mr. Clean Eraser
« Reply #5 on: Tue, 20 August 2013, 14:07:41 »
Mr. Clean Eraser
The magic eraser is a mild abrasive, just so you know.
