Author Topic: Does anyone know about BTC 5151 keyboards?  (Read 2007 times)
Offline berserkfan
Re: Does anyone know about BTC 5151 keyboards?
« Reply #1 on: Wed, 21 August 2013, 14:16:31 »
Beware that "clicky" on eBay is not the same as "clicky" in the real world.
« Reply #2 on: Wed, 21 August 2013, 15:59:48 »
I believe it's a rubber dome over PCB. BTC rubber domes are supposed to be rather nice for a dome keyboard, but many would say it doesn't compare favorably to a mechanical.
You can see some good pictures of the BTC 5100 kb in this GH post:
http://geekhack.org/index.php?topic=31365.0
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #3 on: Wed, 21 August 2013, 17:16:07 »
http://geekhack.org/index.php?topic=33343.0
There's a Key Tronic version of the same keyboard. Does this mean that BTC and Key Tronic foam and foil keyboards use the same parts?
Bore Awards
  • RIP
    • Boring twaddle
« Reply #4 on: Wed, 21 August 2013, 17:26:00 »
Assuming it's the same as the Key Tronic version, the manual for it is here (search for 5151):
http://www.brutman.com/PCjr/pcjr_docs.html
The Key Tronic version is a foam and foil capacitive keyboard (per the website above).
Edit: here's a photo of a disassembled Key Tronic one: http://blog.modernmechanix.com/mags/Byte/7-1984/keytronic_keyboards/keytronic_keyboards_0.jpg
« Last Edit: Wed, 21 August 2013, 17:50:30 by Daniel Beardsmore »
Bore Awards
