Author Topic: IBM M122 (1394324 ) Terminal Keyboards £39.20 delivered in the UK  (Read 3200 times)
Offline Justblair
    • Justblairs Audio and Electronics Pages
I purchased a 122 key keyboard recently from e-bay from this vendor and was very pleased with the keyboard I got.  The seller is not describing it as a Model M or clicky etc, but the one I got was and was very clean when I got it.  I did some additional work to mine to bring it up to pristene, but even in the condition the seller sent it, it was I would say a great buy and perfectly useful.
Noticed that the same seller is repeating the same advert, so no doubt has more from the same source.  I thought I would mention it here.
http://www.ebay.co.uk/itm/IBM-1394324-TERMINAL-KEYBOARD-/231028768357?pt=UK_Computing_Other_Computing_Networking&hash=item35ca633e65
The IBM 1394324 TERMINAL KEYBOARD is a true buckling spring keyboard.  It uses scan code 3 codes, so you will probably need to add Soarers converter to make it work.  The key layout is non standard as well though is a UK layout in the main.  I ended up buying a full set of Unicomp Keys and an AVR breakout board.  All in all I ended up with an expensive, but near perfect keyboard with some extra keys to play with.
More photos in my Album here...
http://s65.photobucket.com/user/justblair/slideshow/IBM%20122%20Key%20Terminal%20Keyboard
Hope someone else gets a good deal too.
Offline dgreekstallion
  • B.S. Fiend
Re: IBM M122 (1394324 ) Terminal Keyboards £39.20 delivered in the UK
« Reply #1 on: Fri, 13 September 2013, 20:50:11 »
Interesting, thanks.
Recent keyboard fanatic.
Model F-122 convert.
