Author Topic: Source of parts for Model Ms?  (Read 3164 times)
Offline bhtooefr
    • bhtooefr.org
« on: Mon, 17 November 2008, 18:05:47 »
After doing a teardown of my M13 to prove a point, I managed to find the broken part.
It doesn't have a part number on it, though, and I don't think IBM has a hardware maintenance manual for the M13. ;)
So, where would I get the TrackPoint button module for a Model M13? The plastic buttons are the same part as the buttons and ribbon cable (they're glued on,) so I'd need white.
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Mon, 17 November 2008, 18:32:33 »
I'd ask Unicomp.
Offline lowpoly
« Reply #2 on: Tue, 18 November 2008, 04:26:34 »
Or clickykeyboards.
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Tue, 18 November 2008, 08:23:26 »
ClickyKeyboards told me that they had 6-8 M13s lying around that were broken, mainly due to failed TrackPoint mechanisms or dishwasher cleanings, and are going to try to salvage a button set. :D
(The thing with Unicomp is that they wanted $60 to refurbish the board, so I know it won't be cheap.)
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Tue, 18 November 2008, 18:59:53 »
ClickyKeyboards FTW. :D
Offline iMav
« Reply #5 on: Tue, 18 November 2008, 22:07:35 »
Quote from: bhtooefr;11642
Unicomp is reasonable for individual parts.  10 cents per buckling spring/hammer assembly.  $12 for a full membrane sheet for a Model M2.
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Tue, 18 November 2008, 22:11:04 »
Well, they also told me in their quote that they needed the part number, because they were unsure about parts availability.
Offline bhtooefr
    • bhtooefr.org
« Reply #7 on: Fri, 21 November 2008, 13:27:19 »
Posting using this M13... I can definitely recommend ClickyKeyboards. Fast shipping, and the parts are good. The buttons work much, much better than the original buttons. :) It's still for sale, though. (I'm picky about keyboard feel, and this just doesn't quite feel like how I want it to feel.)
