Author Topic: Trying to find a proper USB cable  (Read 2510 times)
Offline Darksair
    • My Homepage
« on: Wed, 28 August 2013, 16:47:52 »
Hi all, I'm searching for a usb — mini usb cable for my keyboard.  It should be coiled (like old school telephone cables) and with a right angle on the mini end.  Amazon provides no result.  Anyone know of any cable like that?
Thanks~~
Offline Tym
Re: Trying to find a proper USB cable
« Reply #1 on: Wed, 28 August 2013, 16:51:13 »
Plenty of cable makers on the forum,  Pexon & TFR make them I know for a fact and I think the bloke from Belgium may too.
Offline Obakemono
« Reply #2 on: Wed, 28 August 2013, 16:57:53 »
I've seen some coiled cables, specially in korean custom pictures, maybe you can find something in classifieds on this forum as there are several people making custom cables.
May i ask, why do you prefer a coiled one?
Offline Darksair
    • My Homepage
« Reply #3 on: Wed, 28 August 2013, 17:04:39 »
Thanks for your replies.  I guess I’ll try to find some custom cables on the forum.
Well basically I want it to be short when I use it on my laptop, but I may want to use it on my desktop where it needs to be a bit longer.
Offline sth
  • 2 girls 1 cuprubber
« Reply #4 on: Wed, 28 August 2013, 17:07:25 »
http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313.TR0.TRC0.Xcoiled+mini+usb&_nkw=coiled+mini+usb&_sacat=0&_from=R40
here's one with an angled connector http://www.ebay.com/itm/5Ft-Spiral-Coiled-USB-MINI-5Pin-5P-right-angle-Male-to-USB-2-0-A-male-plug-Cable-/290957831537?pt=US_USB_Cables_Hubs_Adapters&hash=item43be702d71
i use a yellow buffalo coiled cable, it matched my old hhkb color scheme. i think the yellow is the least obnoxious of the colors they have but if you're into bright colors they're your best bet.
Offline Darksair
    • My Homepage
« Reply #5 on: Wed, 28 August 2013, 17:10:29 »
Nice~~  Thank you for the info!
Offline Obakemono
« Reply #6 on: Wed, 28 August 2013, 17:16:28 »
Jumhhh, interesting, i normally just adjust the number of loops i set free.  :p
Offline Darksair
    • My Homepage
« Reply #7 on: Wed, 28 August 2013, 17:26:55 »
Well yea that also works.  It’s just look kinda messy that way :p
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #8 on: Wed, 28 August 2013, 17:42:39 »
My answer depends a bit on where you're actually located, but I can do that fairly easily as well.
It may be faster to go through say Pexon if you're UK/EU located (Paranoid is Belgium based, but is fully queued if I remember correctly).
