Author Topic: [GB] $60 60% case (Aluminium) (SHIPPING - 99% DISPATCHED! :O )  (Read 335543 times)
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
Re: [GB] The $50 60% Aluminium case and Poker 2 GB
« Reply #50 on: Sat, 31 August 2013, 10:50:53 »
I will have one fingers crossed in the next few weeks
Offline zoolzoo
« Reply #51 on: Sat, 31 August 2013, 11:59:48 »
Probably going to have to hop in on this. Cant have one Poker with an alum case and the other without.  :rolleyes:
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline pexon
    • Pexon PCs
« Reply #52 on: Sat, 31 August 2013, 12:29:30 »
OP updated, were are on good progress to reach 80, should only take a couple of weeks.
Offline Hofy
  • Voids Warranties
« Reply #53 on: Sat, 31 August 2013, 13:31:50 »
OK, I am in for 1.
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
Offline kekstee
« Reply #54 on: Sat, 31 August 2013, 18:12:51 »
Mh, I might be in for a case. I hope there is more information on weight, coating and maybe an assembled picture.
Looks like low profile.
Offline kaiserreich
  • HHKB Elite
« Reply #55 on: Sat, 31 August 2013, 22:36:08 »
This looks very similar to the vortex design.
Am I right, or are they from somewhere else?
Offline Jrwestcoast
« Reply #56 on: Sat, 31 August 2013, 23:20:02 »
I am in for 1
Offline zoolzoo
« Reply #57 on: Sun, 01 September 2013, 06:49:56 »
You're right actually. One of the pics from the vortex facebook is even the same. Probably from the same manufacturer in China.
Offline pexon
    • Pexon PCs
« Reply #58 on: Sun, 01 September 2013, 08:13:11 »
As stated in the IC thread, these are Aluminium ones from Vortex yes.
Offline zoolzoo
« Reply #59 on: Sun, 01 September 2013, 09:38:21 »
missed that sorry
Offline pexon
    • Pexon PCs
« Reply #60 on: Sun, 01 September 2013, 10:16:02 »
All good bro  :-*
Offline darklord1702
« Reply #61 on: Sun, 01 September 2013, 10:17:18 »
How much does it cost for 1 to Vietnam dude ???
Offline pexon
    • Pexon PCs
« Reply #62 on: Sun, 01 September 2013, 10:27:17 »
http://parcel.dhl.co.uk/delivery-prices.php
Take 45% off the price for Rest of World, 0.5kg or 1kg dependent on what you order.
EDIT: Royal Mail would be about £15 GBP, but no tracking outside the UK.
« Last Edit: Sun, 01 September 2013, 10:29:28 by pexon »
Offline zoolzoo
« Reply #63 on: Sun, 01 September 2013, 13:36:15 »
Anyone notice the burring on the circular imprints...espec toward the left of the case? Looks like plastic not milled alum. No?
« Reply #64 on: Sun, 01 September 2013, 13:38:22 »
Probably because these are cast, not milled, aluminum. :)
Offline pexon
    • Pexon PCs
« Reply #65 on: Sun, 01 September 2013, 14:15:57 »
As JD says, these are cast, not milled, hence the lower cost.
Offline zoolzoo
« Reply #66 on: Sun, 01 September 2013, 16:03:49 »
oh cool. ok going to order one.
Offline pexon
    • Pexon PCs
« Reply #67 on: Mon, 02 September 2013, 02:53:36 »
OK dude, just fill out the order form as per  :thumb:
Offline pexon
    • Pexon PCs
« Reply #68 on: Mon, 02 September 2013, 08:11:27 »
OP updated again, getting closer to the MOQ, keep 'em coming dudes.
Offline LechnerDE
« Reply #69 on: Mon, 02 September 2013, 08:17:24 »
I just had to look up these words in the dictionary  :p
What does this mean quality wise? How exactly is a milled case 3x more expensive? What's the major difference?
Offline pexon
    • Pexon PCs
« Reply #70 on: Mon, 02 September 2013, 08:20:05 »
Well, the quality will not be as good as a milled case, but it will still be far superior to plastic. Casting is cheaper as it uses less material. A Milled case is milled from 1 solid piece of aluminium and there is a lot of waste, but the strength will be slightly better.
Offline LechnerDE
« Reply #71 on: Mon, 02 September 2013, 08:31:20 »
Ah, I see. Sounds good enough for me ;)
I will probably place my order when the deadline approaches.
Offline zoolzoo
« Reply #72 on: Mon, 02 September 2013, 10:49:30 »
submitted
Offline pexon
    • Pexon PCs
« Reply #73 on: Mon, 02 September 2013, 10:56:46 »
« Reply #74 on: Mon, 02 September 2013, 13:57:17 »
Will this work with a pure pro? I'm considering ordering one when I have the money (exactly 1 month from today).
Offline Shinryuu
« Reply #75 on: Mon, 02 September 2013, 15:52:14 »
Damn, this looks pretty interesting (... and the price isn't that bad). If I order a one, let's hope 'shipping/postal dudes' won't rape stuff this time around :p Keep us updated pexon -boya :thumb:
(ノ◕ヮ◕)ノ*:・゚✧
Offline pexon
    • Pexon PCs
« Reply #76 on: Mon, 02 September 2013, 15:58:39 »
Yea man, the Royal Mail tend to be poo, hence I'm choosing a reputable courier this time!  :thumb:
Offline Shinryuu
« Reply #77 on: Mon, 02 September 2013, 16:03:02 »
I'm glad to hear that!
(ノ◕ヮ◕)ノ*:・゚✧
Offline do_Og@n
« Reply #78 on: Mon, 02 September 2013, 21:44:27 »
I'm guessing these will work with the upcoming GH60. If so put me down for one.
Only question....will invoicing start as soon as the MOQ is met?
Offline battletux
« Reply #79 on: Tue, 03 September 2013, 01:48:06 »
If/when this is confirmed to work with the gh60 then I'll be in for 2. That's the only thing stopping me from pulling the trigger on these.
Once your sample arrives would you be able to check with komar if it would fit?
Offline pexon
    • Pexon PCs
« Reply #80 on: Tue, 03 September 2013, 03:17:43 »
Yes, I will contact him as soon as one comes  :thumb:
Offline concept73
« Reply #81 on: Tue, 03 September 2013, 08:44:12 »
Interesting Pexon, very interesting.
P.S. I’m going to steal your HHKB@i50!
Poker 2 with reds
Soon to be a JD40 with reds
Offline pexon
    • Pexon PCs
« Reply #82 on: Tue, 03 September 2013, 08:52:25 »
nope.avi
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #83 on: Tue, 03 September 2013, 09:13:19 »
I'm kind of interested, but can you give more information about the 60% aluminium case? What are the rest of the 40%?
Offline pexon
    • Pexon PCs
« Reply #84 on: Tue, 03 September 2013, 09:19:13 »
WHA??????  ???
« Reply #85 on: Tue, 03 September 2013, 09:24:16 »
WHA??????  ???
Ah! I'm sorry. I understand now. 60%= kb size.
I originally thought that it was 60% aluminium+ 40% other materials, that's why it was only $50.
« Reply #86 on: Tue, 03 September 2013, 09:28:01 »
60% Aluminum alloy
31.23% Nitrogen
8.38% Oxygen
0.37% Argon
0.13% Carbon Dioxide
/joke about composition of air
Offline aggiejy
« Reply #87 on: Tue, 03 September 2013, 09:36:58 »
I just filled out the form, though I only really want it if it's GH60-compatible.  So if it turns out that it won't fit, I may need to cancel (if it's not too late).  Else, I guess I'll resell it or something.  :)
« Reply #88 on: Tue, 03 September 2013, 09:42:13 »
While nothing in this life is guaranteed 100%, I can assure you this case will almost certainly fit the GH60 perfectly. One of the key factors in the design spec of the GH60 was that it fit into existing Poker cases. There should be nothing at all to preclude the GH60 from fitting into future Poker/Pure/Poker II/Pure Pro cases, as well.
Offline pexon
    • Pexon PCs
« Reply #89 on: Tue, 03 September 2013, 10:03:24 »
If it was a joke, it went right over my head  ^-^
Offline pexon
    • Pexon PCs
« Reply #90 on: Tue, 03 September 2013, 13:05:49 »
Order list updated
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #91 on: Tue, 03 September 2013, 13:30:42 »
What are the odds of us getting a shot of this assembled with a Poker/Poker II PCB? I'm basically sold on the case, but was hoping that I could see the finished product, so to speak.
Offline pexon
    • Pexon PCs
« Reply #92 on: Tue, 03 September 2013, 14:25:24 »
I am getting some Pokers in next week, need to hear back from my contact about getting a sample.
Offline Bencze
« Reply #93 on: Tue, 03 September 2013, 16:05:31 »
Would we get tracking information (EU) when you send it?
-= QFR w/ mx blues - HPE87 w/ mx browns - Ducky 1087XM w/ green alps =-
Offline bakteria
« Reply #94 on: Tue, 03 September 2013, 17:20:51 »
Lovely! Need a case for my pure!
Deadline fits me perfectly as well since I'm low on funds atm.
SS 7G black - Pure red - poker blue (MKC Tray)
Offline turtle
« Reply #95 on: Tue, 03 September 2013, 17:32:25 »
Order submitted. Thanks can't wait.
Offline pexon
    • Pexon PCs
« Reply #96 on: Tue, 03 September 2013, 17:38:45 »
Tracking for all parcels mate, yes, no matter where!  ;)
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #97 on: Tue, 03 September 2013, 19:00:16 »
Whelp, I guess I'm in now.
Offline Full_Battle_Rattle
« Reply #98 on: Tue, 03 September 2013, 23:14:22 »
I'm pretty excited to see how they look together. Keep up the good work!
Offline pexon
    • Pexon PCs
« Reply #99 on: Wed, 04 September 2013, 04:38:39 »
OP updated
