Author Topic: Nighthawk X8  (Read 3374 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Nighthawk X8
« on: Thu, 29 August 2013, 18:24:06 »
Ok I found a Nighthawk X8 instead of ducky. Now would an alienware 06G6JW motherboard support going into the bios? I see that it has NKRO is that over PS2 or USB?
Offline jabar
Re: Nighthawk X8
« Reply #1 on: Thu, 29 August 2013, 19:46:31 »
if it doesn't do the NKRO over USB hack, then there should not be any BIOS issues.
since Max keyboards don't do this, yes, there should be no BIOS problems.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline C5Allroad
Re: Nighthawk X8
« Reply #2 on: Thu, 29 August 2013, 19:54:27 »
Ok nice! Windows should work also?
Offline jabar
Re: Nighthawk X8
« Reply #3 on: Thu, 29 August 2013, 19:58:58 »
I'm not familiar with that motherboard - I was responding to the keyboard question which is a real issue for some keyboards (Noppoo, Ducky DIP switch setting, etc).
The keyboard, itself considered, is most compatible with Windows.
Phantom 7bit
Offline Hyde
  • White Tofu Extraordinaire
Re: Nighthawk X8
« Reply #4 on: Thu, 29 August 2013, 20:17:49 »
It looks like USB NKRO, so whether it works or not in bios is a huge maybe.
Offline C5Allroad
Re: Nighthawk X8
« Reply #5 on: Thu, 29 August 2013, 20:27:11 »
Ok guys thanks for the replies. :) I'm used to it not working in the bios K90..... I have a membrane keyboard lying around if I need to hop into the bios was just wondering if it would work. So as long as I'm in windows it should work with NKRO?
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: Nighthawk X8
« Reply #6 on: Thu, 29 August 2013, 20:31:52 »
ProTip: the X51's "06G6JW" motherboard is a corner-and-quality slashed MSI H61 board. Dell was so cheap, they didn't even opt for the battery holder.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline jabar
Re: Nighthawk X8
« Reply #7 on: Thu, 29 August 2013, 20:41:12 »
well ****, looks like I'm wrong...
Phantom 7bit
Offline C5Allroad
Re: Nighthawk X8
« Reply #8 on: Thu, 29 August 2013, 20:46:38 »
So what does that mean for me?
Offline rootwyrm
    • My Website!
Re: Nighthawk X8
« Reply #9 on: Thu, 29 August 2013, 22:54:23 »
No USB N-KRO. Not that 99% of people can even use it. Highly unlikely Dell licensed UEFI USBHID since they had MSI slash quality and make the part in China.
Offline C5Allroad
Re: Nighthawk X8
« Reply #10 on: Fri, 30 August 2013, 22:53:06 »
Oh ok. So what about the K70 would the NKRO on that keyboard work?
Offline falkentyne
Re: Nighthawk X8
« Reply #11 on: Sat, 31 August 2013, 02:01:31 »
Ducky Shine 3 definitely works fine in Bios, even though it DOES do Nkey rollover in windows, it's only 6 key in Bios.
I tested it on an old Abit BH6 motherboard, and the shine 3 worked fine in real mode DOS and in Bios.  Only 6 key rollover there.
Offline C5Allroad
Re: Nighthawk X8
« Reply #12 on: Sun, 01 September 2013, 00:44:11 »
I don't care about NKRO in bios I just care that I can get in and work in the bios.
