Author Topic: Ducky shine3 or wasd v2?  (Read 2201 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Sun, 01 September 2013, 20:21:25 »
Well i'm looking into buying my first mech keyboard soon and i was wondering what you recommend for a keyboard.
What i was thinking either the shine 3 TkL (expecting it to be out soon) or the wasd v2 but i can't make up my mind over the two and i was wondering if anyone could throw in their opinion on a keyboard, my budget is 160-170 max on the 150 or lower is always nice!
I prefer Cherry mx blues also, And i also prefer tenkeyless boards.
« Last Edit: Sun, 01 September 2013, 20:25:59 by Air tree »
Offline Photoelectric
Re: Ducky shine3 or wasd v2?
« Reply #1 on: Sun, 01 September 2013, 20:28:27 »
They are pretty different... Shine III is backlit and you can select the color of backlighting, whereas V2 is not backlit.  I'm sure both will be great keyboards, but you'll be paying more for Shine III due to the LEDs..  You will have to wait a while for Shine 3 TKL versions, as they still have not been released.
Offline Air tree
« Reply #2 on: Sun, 01 September 2013, 20:30:05 »
Both keyboards cost exactly the same. But i do enjoy what i can do with the colours of the key caps on the wasd v2 i also like the backlighting of the shine 3.
But i'm also open to other recommendations.
Offline dante
« Reply #3 on: Sun, 01 September 2013, 20:32:03 »
Buy both, sell the one you don't like.
« Reply #4 on: Sun, 01 September 2013, 20:37:21 »
Ah right with keycaps.  There's a barebones version for $100, without caps.  Many of us already have extra cap sets, so I was only considering the barebones version.  I think Ducky Shine III is a better deal at that unless you need Dvorak or Colemak--if you're going to be buying the version of V2 with caps.
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #5 on: Mon, 02 September 2013, 02:03:26 »
Does anyone know if the v2 will fit custom tkl cases?
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline terran5992
  • One With The Cup Rubber
« Reply #6 on: Mon, 02 September 2013, 02:39:22 »
I dont think they will. custom tkl cases are very specfic
Offline ITzNybble
« Reply #7 on: Mon, 02 September 2013, 03:15:34 »
Yes I knew the v1 wouldn't fit the vortex ALU cases.
« Last Edit: Mon, 02 September 2013, 08:36:31 by ITzNybble »
