Author Topic: Its Blue! ( QFR sanding and painting tips inside! )  (Read 52047 times)
Offline Jixr
Re: Its Blue! ( QFR sanding and painting tips inside! )
« Reply #50 on: Mon, 02 December 2013, 12:07:38 »
Another Update ( not sure if the contest is over or not, but I figured I might as well keep it going )
Got my second set of PBT front printed caps ( like my XT has ) to put on my QFR
Also lubing the reds, and since I've found a new love with lubed blacks, I may convert the reds to blacks via spring swapping ( I like the red plate too much to just go buy a stock qfr with mx blacks ) I did go ahead and changed the XT to full mx blacks ( lubed ) they feel amazing to me. and by far the best switch i've ever tried so far.
Photos will be up later today once I finish lubing the reds ( takes the scratchyness away ) and get the new caps on and clean it up a bit.
and thanks for all the compliments guys, means a lot.
Offline cherpalla
« Reply #51 on: Thu, 02 January 2014, 15:41:27 »
It's so pretty!! I wish I could pull something like this off. I just have to hope someone is willing to be paid to paint my QFR for me.... :))
c h e r
Offline do_Og@n
« Reply #52 on: Fri, 03 January 2014, 12:01:46 »
Oh I'm sure you'll be able to find somebody. You can also order a spare top case from the CMstore for practice if you get curious.
Offline cherpalla
« Reply #53 on: Fri, 03 January 2014, 12:53:58 »
Thanks, maybe I will give it a shot. I painted some parts on my case that were black white... I'm just scared of the sanding and all and it turning out terrible.
c h e r
Offline Jixr
« Reply #54 on: Fri, 03 January 2014, 21:44:51 »
its pretty hard to mess it up where its un-fixable.
I need to update this with more current pictures.
Offline Jixr
« Reply #55 on: Sat, 04 January 2014, 22:34:54 »
updated, got some new keycaps awhile back and just made a custom cable for it today. Looks really nice now.
Offline cherpalla
« Reply #56 on: Sun, 05 January 2014, 13:39:27 »
 :thumb: It's beautiful!!
c h e r
Offline RESPRiT
  • HHKB = ❤
« Reply #57 on: Fri, 10 January 2014, 07:20:14 »
Your paint jobs are amazing! How is your first job doing? Has it been affected by wear very much?
Offline Jixr
« Reply #58 on: Fri, 28 March 2014, 22:22:18 »
nope still looks good and is holding up great ( also have my QF XT in the same color )
Offline boradori007
  • I'm trippin bear balls.
« Reply #59 on: Wed, 02 April 2014, 03:09:36 »
ta-da! now my XT looks just like my QFR
so much better than the regular case  :thumb:
Offline ajunakey
« Reply #60 on: Sun, 06 April 2014, 02:08:58 »
very clean man
Offline Demetrium
« Reply #61 on: Tue, 15 April 2014, 12:47:16 »
Awesome! Looks nice!
Offline taylordcraig
« Reply #62 on: Sun, 20 April 2014, 01:01:12 »
Looks quite good, nice job.
Offline tigersharkdude
« Reply #63 on: Sun, 20 April 2014, 20:08:56 »
OP, where did you find those white side printed keycaps? I can't find any
Offline cmadrid
« Reply #64 on: Mon, 28 April 2014, 13:29:38 »
Do you think sanding sticks for modeling would be good for getting at the small bits of rubber in the corners easier?
« Reply #65 on: Tue, 29 April 2014, 21:45:41 »
That may work, I used a sanding block/sponge from Lowes. It was like $2.5 (for just one)
http://www.lowes.com/pd_214284-98-SSG-F-2PK_0__?productId=4177071&Ntt=sanding+sponge&pl=1&currentURL=%3FNtt%3Dsanding%2Bsponge&facetInfo=
Offline cmadrid
« Reply #66 on: Wed, 30 April 2014, 00:53:53 »
I thought about getting one of those, but I'm only really having an issue getting at the tiny spots like inside the space for the Esc key and arrow cluster
Offline Jixr
« Reply #67 on: Wed, 30 April 2014, 15:22:43 »
I just used regular sandpaper, took some work, but I got it done.
Offline slickmamba
« Reply #68 on: Fri, 02 May 2014, 21:02:09 »
That is awesome!  Makes me want to pick one up now that newegg has them for 70!
Hi :)
Offline sebk
« Reply #69 on: Thu, 08 May 2014, 14:16:43 »
Thanks for the paintjob tips! Love the keycaps. So cool!
Offline krunchwrap
« Reply #70 on: Mon, 19 May 2014, 17:18:10 »
I think this looks great! Awesome color and very well done, great job!
Offline barkinos98
  • Illinois
« Reply #71 on: Mon, 04 August 2014, 15:39:30 »
Great tips man!
Happy Hacking Professional 2  | Logitech G710+ | Quickfire Rapid MX Clears
Offline ADFX_Pixy
« Reply #72 on: Sat, 27 September 2014, 15:06:33 »
That red goes sooooo well with the blue. Wow...  :eek:
CM Storm Quickfire Stealth Cherry MX Brown
Mechanicalkeyboards.com MK 2016 Cherry MX Brown
