Author Topic: ibm keyboard model m  (Read 55501 times)
Offline majrie
« on: Tue, 03 September 2013, 04:01:38 »
Where do i attach this?
Re: ibm keyboard model m
« Reply #1 on: Wed, 04 September 2013, 10:13:49 »
I can't really see in the picture but...
If that is a flat piece of sheet metal with a hole in it, then I think that it should be bolted together with the other cable to the metal back plate.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #2 on: Wed, 04 September 2013, 16:29:00 »
On the Model M's that have 2 grounds, doesn't the second go to the spacebar? That second ground is missing it's other end, see if you can find it where you opened it up.
EDIT: Nevermind, the spacebar ground looks different it seems.
« Last Edit: Wed, 04 September 2013, 16:32:43 by The_Ed »
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline majrie
« Reply #3 on: Wed, 04 September 2013, 17:10:49 »
It is bolted together with the other one. But my trouble is where to put the loose end. Hope you can tell me or where can i ask? Thank you
« Reply #4 on: Wed, 04 September 2013, 17:43:48 »
If I can see correctly, the bare wire end should actually be coming out of the keyboard cable.  The lug on the other end should be bnolted to the chassis with teh same bolt as the lead coming from the circuit board.
