Author Topic: Mechanical keypad that works in OS X?  (Read 2873 times)
Offline Architect
  • TECK Lover
« on: Tue, 03 September 2013, 18:22:38 »
Any suggestions of ones you've tried? If you have a mechanical keypad and a Mac could you try for me?
I tried the Filco Brown keypad, and when you press the Num Lock or = keys the keypad locks up. Returning and looking for another.
TECK 209 Blank Keys; Leopold Number Pad; X-Keys Professional; X-Keys 84.
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Mechanical keypad that works in OS X?
« Reply #1 on: Tue, 03 September 2013, 19:25:18 »
With Ducky shine you have a DIP switch in which you can swap the windows key with the alt key. All keyboards will work but certain features work your keyboard will work. Good luck.
Offline Tony
« Reply #2 on: Wed, 04 September 2013, 02:43:19 »
I think you should ask Apple to give you a good keyboard driver instead.
Offline mapple
« Reply #3 on: Wed, 04 September 2013, 05:01:43 »
ducky works perfectly under osx at least the one which i have dk9008g2 pro
In God We Trust
« Reply #4 on: Wed, 04 September 2013, 05:03:20 »
He's looking for a keypad (10-key pad) not a keyboard.
Offline Architect
  • TECK Lover
« Reply #5 on: Wed, 04 September 2013, 05:28:56 »
Right, thanks Photekq. I'm looking for an external keyPAD or number pad.
There's the Filco key PAD with Browns, but it locks up when hitting the num key.
There's the Adesso with Blue's I believe (unfortunately), anybody tried it with OS X?
Others?
Offline daerid
    • Rossipedia
« Reply #6 on: Wed, 04 September 2013, 08:26:12 »
Offline Architect
  • TECK Lover
« Reply #7 on: Wed, 04 September 2013, 08:39:44 »
You could try the Leopolds:
http://www.elitekeyboards.com/products.php?sub=leopold,tenkeypads
Thanks, I sent an email to their customer service to see how well it plays with a Mac
Offline C5Allroad
« Reply #8 on: Thu, 05 September 2013, 13:12:09 »
Whoops, thought he said keyboard. Keycool has a 22 key mechanical keypad that is backlit.
Offline Wildcard
  • When caffeine isn't enough
« Reply #9 on: Thu, 05 September 2013, 14:22:56 »
Goldtouch makes a Mac version of their keypad
« Last Edit: Thu, 05 September 2013, 14:25:29 by Wildcard »
Offline spiceBar
    • ChessTiger.com
« Reply #10 on: Thu, 05 September 2013, 14:43:38 »
I have exactly the same model and exactly the same problem. On a Mac.
I don't think the keypad is defective. I even think you may have the same problem with keypads from other brands. My guess is that Mac OS is the culprit here.
Instead of losing time on this problem, I have ordered Filco key locks:
http://www.keyboardco.com/product/filco-key-locks-pack-of-10.asp
and put them on the keys that lock the keypad up. Problem solved. Next.
Offline Architect
  • TECK Lover
« Reply #11 on: Thu, 12 September 2013, 20:39:23 »
OK, I got the Leopold keypads and they work PERFECTLY. All the keys, both with num lock and without, act as you would expect. The only key which doesn't work is the "Insert" (Num Lock off) key, but that makes perfect sense, as OS X doesn't support insert.
Great keypads, they mate well with my TECK keyboard, and they work great with OS X. Cheaper than Filco's too.
Offline C5Allroad
« Reply #12 on: Thu, 12 September 2013, 20:42:13 »
Nice! Grats on purchase! :thumb:
