Author Topic: it was mistake? or i was cheated? ibm model m2 question  (Read 3639 times)
Offline mapple
« on: Wed, 04 September 2013, 13:19:18 »
hey guys n girls.
as in topic today i received ibm model m2 bought on ebay.
precise description was "VINTAGE IBM CLICKY MECHANICAL KEYBOARD MODEL M2 WP1 PS/2, TWO TONE, TESTED WORKS".
but it doesn't give feedback neither click. Worst thing was when i did poped up keycap and saw rubber ......... as u can see on pictures below.
my question before i make case to ebay (and seller). i made mistake? i mean m2 should be build on BS right? only lighter springs? i don't wanna make fool of myself so wanna to verify with u guys before i make any steps further.......
In God We Trust
Offline zoolzoo
Re: it was mistake? or i was cheated? ibm model m2 question
« Reply #1 on: Wed, 04 September 2013, 13:27:39 »
I would raise a stink, description was misleading. It did say "M2" but it certainly isnt clicky, so you were confused by the sellers careless title. I would even file a dispute if the seller doesnt let you return it. The worst that happen is that you lose and have to keep the board.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline mapple
« Reply #2 on: Wed, 04 September 2013, 13:30:54 »
i will do that for sure but my question is......... Does normal ibm model m2 is build on buckling springs?
In God We Trust
Offline zoolzoo
« Reply #3 on: Wed, 04 September 2013, 13:35:50 »
Im not an IBM expert but I thought the M2 has buckling springs but was a smaller board with a shorter throw. Im not really sure what you have there actually... but in any case the description is wrong.
Offline BlueBär
« Reply #4 on: Wed, 04 September 2013, 14:11:27 »
There was a M2 RD version, but the board you got is neither clicky nor mechanical, so misleading description.
Although the model number you have is not on Wikipedia, I guess that Model M2s that have model numbers that start with a 7 are RD boards, at least every RD board noted there has one and there is no non-RD board that has a model number that starts with a seven.
Offline Hellmark
« Reply #5 on: Wed, 04 September 2013, 14:14:08 »
Unfortunately, there are some that were made with rubber domes. The 73G4614 was used with early Aptivas, and 60G0817 was another M2 with rubber domes. Avoid ones with a removable plastic border, as those have rubber domes.
Try and look for a 1395300, which is what was used with the PS/1. 60G3570, 42H0468,  and 1395900 I think were also ones with buckling springs, but don't quote me on it.
As far as your issue, I would talk to the seller, since it is most certainly not a mechanical keyboard.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Wed, 04 September 2013, 14:30:34 »
from my experience...........unless the item being sold says "as is" i have been able to recoup my money from the seller without anybody, but you have to pick up shipping.
also from experience if you cannot resolve with seller, then proceed to open a dispute expect to offer up evidence you were misguided proving the seller was misleading, etc. and then will have wait for a decision where "ebay" will forcibly get your money from the seller and refund.
took about 4-5 weeks on mine if i recall
i thought i had a g80-18xx one time (had 1.5 mods, etc.), but the label on the back was rubbed off and it was really a g81
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Wed, 04 September 2013, 14:31:59 »
scribal error............
without any problem
Offline mapple
« Reply #8 on: Wed, 04 September 2013, 16:40:06 »
i did wrote @ to seller hopefully he will send cash and money for shipping. if he won't, i'll create case in ebay........ for all you people let my case be a hard lesson...... sad one ........
In God We Trust
Offline Tym
« Reply #9 on: Wed, 04 September 2013, 16:47:37 »
The seller wont cover your shipping they never do, and you dont get a refund until they get the board back.
