Author Topic: Question about the original Poker DIP switches  (Read 3212 times)
Offline spiceBar
    • ChessTiger.com
« on: Thu, 05 September 2013, 12:14:49 »
I have looked around and I cannot find a clear answer to a question, so my apologies if this has already been covered somewhere.
On the original Poker (I think the exact name is Poker X, I'm not talking about the more recent Poker II), there is a DIP switch that does "Window_L Change to FN_L" (sic). It's how it is described in the manual.
My question is: does it swap the Fn and Win keys (like on the FC660C for example), or does it make the left Win key a second Fn key?
Since I do not have the keyboard, I cannot simply try.
Thank you in advance for your answers.
Offline Obakemono
Re: Question about the original Poker DIP switches
« Reply #1 on: Thu, 05 September 2013, 12:44:19 »
Don't have one, but i guess it swaps, at leas this is what makes sense to me.
Offline spiceBar
    • ChessTiger.com
« Reply #2 on: Thu, 05 September 2013, 14:05:28 »
Yes, and I hope it does, but by reading some reviews I am left under the impression that it turns the left Win key into a second Fn.
BTW, this tells something about reviews. Every one of them describes the same things over and over in great lengths, like the texture of the keys or the font of the side prints. And a lot of time went into taking HQ pictures of the thing. But some basic features are not even covered.
These guys would lick the PCB and tell you about the taste, but they did not even try the various DIP switches options.  :))
Offline AuRinBei
« Reply #3 on: Thu, 05 September 2013, 15:29:05 »
I am pretty sure it just turns LWin into LFun. That is what the Poker II says it does. Although I am confused about some things regarding the Poker II. I saw one review saying that you couldn't switch the LCtrl and Capslock keys at the hardware level, but I want to know from someone who has a Poker II. It seems like you should be able to, since neither of them trigger any programming functions, although one of the DIP switches does switch LWin/LFfun and Caps, so maybe that would cause problems. I don't understand how people are making boards anymore that don't have a Caps -> Ctrl dip switch...
87u || Poker 2
Offline spiceBar
    • ChessTiger.com
« Reply #4 on: Thu, 05 September 2013, 20:45:18 »
C'mon guys, I'm pretty sure there are plenty of Poker owners on this forum... The question is an easy one...
Thank you in advance!
Offline Neal
  • Skype: iNewbcake
« Reply #5 on: Fri, 06 September 2013, 04:56:01 »
I have one, it doesn't swap them. It just makes the left windows key also an fn. Resulting in having 2 fn keys.
Offline spiceBar
    • ChessTiger.com
« Reply #6 on: Fri, 06 September 2013, 06:26:14 »
OK! Thank you very much!
Offline yasuo
  • spanengan puyeng newbie
« Reply #7 on: Fri, 06 September 2013, 06:39:00 »
Poker X you mean?
Same my Poker X can't switch on DIP 4
I' don't know too :(  if can, it easy to use arrow keys on WASD
« Last Edit: Fri, 06 September 2013, 10:09:56 by yasuo »
Logitech MK220 Colemak DH
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #8 on: Fri, 06 September 2013, 09:52:24 »
I tested it on one of my Poker X boards. According to the manual it's supposed to turn the left Win Key into a left FN key, but in my experience it did not do that. The left WinKey no longer registered as a WinKey, but it did not function as an FN key either. The right FN key continued to work, as expected, but the left FN key did not allow me to use any of the FN layer items.
I don't believe DIP Switch 4 is functional. I vaguely remember someone saying that in a thread somewhere, but I can't recall it at the moment. In my experience, using a Mac, it did not work as intended.
Hope that helps!
Offline spiceBar
    • ChessTiger.com
« Reply #9 on: Fri, 06 September 2013, 10:10:54 »
Hope that helps!
Your DIP switch is reversed. From what I have read, this was a production error on the first model.
So by activating switch#4, you have deactivated the Win key, which is what switch 1 does.
Here are the DIP switches functions (Poker X without the production mistake, from the manual):
Switch 1 ON = Window_L(FN_L) Lock
Switch 2 ON = FN_L(Window_L) , ALT_L Swap Position
Switch 3 ON = Caps Lock , Ctrl_L Swap Position
Switch 4 ON = Window_L Change To FN_L
Here is what yours are (Poker X with the production mistake):
Switch 4 ON = Window_L(FN_L) Lock
Switch 3 ON = FN_L(Window_L) , ALT_L Swap Position
Switch 2 ON = Caps Lock , Ctrl_L Swap Position
Switch 1 ON = Window_L Change To FN_L
Can you try switch 1, please?
Offline mashby
    • Mashby
« Reply #10 on: Fri, 06 September 2013, 13:30:03 »
You're exactly right. When I turned on Switch 1, the left WinKey became a FN key and worked as expected. The right FN key continued to work the same regardless.
Offline spiceBar
    • ChessTiger.com
« Reply #11 on: Fri, 06 September 2013, 13:38:17 »
OK, great. Thank you very much for trying it and for reporting the result.
Offline Neal
  • Skype: iNewbcake
« Reply #12 on: Sat, 07 September 2013, 10:48:04 »
Mine was reversed too, confused me at first.
Offline nuclearsandwich
« Reply #13 on: Sat, 07 September 2013, 21:22:23 »
SW 1 on the Poker II turns Left Caps into a Left WIN key. To make it a CTRL you have to program it to one and then toggle the programmed layer on.
