Author Topic: Help with Keycaps KBT PURE PRO  (Read 2595 times)
Offline yjfknt
« on: Fri, 06 September 2013, 14:52:30 »
Hi guys,
I'm new here first post being lurking for a while though.
I just recently bought a KBT Pure Pro, the ones with arrow keys. The keycaps I got with these are blank PBTs.
I want to get some novelty key caps, or even just some different color caps for my esc,arrow keys and numbers on top. Preferably PBT but ABS can work.
The reason why I'm asking is because my friend told me some of the keycaps will sit lower than normal and I do not want that to happen.
Thanks in advance!
Offline Kiric
Re: Help with Keycaps KBT PURE PRO
« Reply #1 on: Fri, 06 September 2013, 23:00:16 »
You need to find keycaps with OEM profile then you'll get  the same height for all your keycaps.  :)
