Author Topic: Question about Poker II keycap sizes.  (Read 3243 times)
Offline acer589
  • Gotta get out of college
« on: Tue, 10 September 2013, 02:09:36 »
 Are the keycaps on the Poker II pretty much standard sized? Like... would I be able to use an 84-key set and just have some left over?
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
Offline dragonxx21
Re: Question about Poker II keycap sizes.
« Reply #1 on: Tue, 10 September 2013, 02:12:19 »
I think the Poker II uses standard cherry keycaps? Don't quote me on it though.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline BlueBär
« Reply #2 on: Tue, 10 September 2013, 02:15:34 »
The Poker has a standard ANSI layout.
Offline acer589
« Reply #3 on: Tue, 10 September 2013, 02:23:55 »
So, would I want to order an 84 or 87 set? Or would it not matter?
Sorry for the nooby questions.
Offline dragonxx21
« Reply #4 on: Tue, 10 September 2013, 02:33:49 »
Is there anything from the 87 set that you would need? If not, then no.
Keyboards Owned:
Offline BlueBär
« Reply #5 on: Tue, 10 September 2013, 02:38:46 »
Which sets are we talking about? Never seen a 84-key set, could be for a 75% which might not fit, they often use non-standard keycap sizes.
Offline acer589
« Reply #6 on: Tue, 10 September 2013, 02:43:44 »
So, I should go 87 then? To be clear, these are the two I was looking at:
Link 1
Link 2
Offline BlueBär
« Reply #7 on: Tue, 10 September 2013, 02:50:54 »
Just as I expected, the 84-key set is for a 75% board, in this case the Keycool 84. They will not fit the Poker II (1x1 bottom row modifiers, short right shift, etc.).
Go for the 87-key set.
Offline acer589
« Reply #8 on: Tue, 10 September 2013, 10:41:53 »
Awesome! thanks a bunch for the help!
