Author Topic: Keycool 84 - Blacks + o-rings = no difference?  (Read 1187 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Wed, 11 September 2013, 07:17:08 »
Hey guys, made a post the other day asking if o-rings would affect my typing experience, if so, how etc.
So the o-rings finally came and tbh, it feels no different when typing or even touching the keys, I put a few of the o-rings onto a mx cherry red board that I have and you can feel the different right away, but on blacks? I cannot seem to tell the difference what so ever. The sound is dampened ever so slightly, but it's hard to really notice a change.
The o-rings that I got where:
70a-0.2em black o-rings.
Has anybody else used o-rings on blacks and experienced this also?
你搞砸了
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
Re: Keycool 84 - Blacks + o-rings = no difference?
« Reply #1 on: Wed, 11 September 2013, 09:22:52 »
my guess is since the blacks have more resistance to your push, you were barely bottoming out to begin with, so adding a ~2mm o-ring you probably are just barely hitting it and that is why it sounds slightly quieter, but with reds you were bottoming out all the way due to the light spring so adding o rings makes a difference. just my 2 cents.
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline PointyFox
« Reply #2 on: Wed, 11 September 2013, 09:39:19 »
What is a "70a-0.2em" o-ring?  I'm guessing 70a is the hardness in Shore A and that "em" is supposed to read "cm"?  So, 70 Shore A hardness and 0.2 cm thick?
Offline Polymer
« Reply #3 on: Wed, 11 September 2013, 16:03:36 »
Are they the same boards?
Use the same keycap on both and see if it makes the same difference or not...
