Author Topic: Good PCB mounted boards?  (Read 3471 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Wed, 11 September 2013, 16:16:37 »
Hi guys again with this whole internet thing for me I'm wanting a PCB mounted board now. I heard you can change the stems and springs with out having to desolder and resolder, which is a huge plus for me. I don't really care for backlighting since I will be buying blank keycaps.
I kind of want NKRO if a such a keyboard exists with it over USB since my motherboard doesn't have a ps2 port :( this will be after I buy a shine 3 though.
Re: Good PCB mounted boards?
« Reply #1 on: Wed, 11 September 2013, 16:39:22 »
What size? the race, pure and poker x are all good pcb mounted boards, though they "only" have 6kro over usb I think. They are also smaller than tkl
Of course your best option is to get an ergoDOX as it supports full NKRO over USB, is fully programmable, the keyswitch-tops are removable without desoldering, AND it's ergonomic.
Offline C5Allroad
« Reply #2 on: Wed, 11 September 2013, 17:36:30 »
I was looking for full size or TKl with the home/pageup cluster and my arrow keys which I use a lot lol.
Offline C5Allroad
« Reply #3 on: Wed, 11 September 2013, 17:42:53 »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Thu, 12 September 2013, 10:26:56 »
It's a short list...
Full size: Cherry G80 line
TKL: Neo Zelia
mini: Poker X, Pure, Race
None of them have more than 6KRO over USB. I don't see how it's a big deal NKRO unless you have 4 hands or something?
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Thu, 12 September 2013, 10:27:44 »
Plover
Offline watterrbottle
« Reply #6 on: Thu, 12 September 2013, 12:57:59 »
if the board has LEDs don't you have to desolder them to open the switches?
« Reply #7 on: Thu, 12 September 2013, 13:03:08 »
You're correct, yes you have to desolder the LEDs in order to open the switches.
« Last Edit: Thu, 12 September 2013, 13:10:42 by CPTBadAss »
« Reply #8 on: Thu, 12 September 2013, 13:05:47 »
No, if it has LED it is going to keep the switch top from being opened.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #9 on: Thu, 12 September 2013, 13:08:32 »
NKRO is just a marketing ploy in my opinion. Go 60% because it is just plain amazing. Poker X if you can get one.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline C5Allroad
« Reply #10 on: Thu, 12 September 2013, 16:25:02 »
Is there a tenkeyless PCB mounted board? I would really love one.
Offline meiosis
  • Time
« Reply #11 on: Thu, 12 September 2013, 16:27:46 »
doing tp4's work ;)
Keyboards:
Aripeko TKL
Offline C5Allroad
« Reply #12 on: Thu, 12 September 2013, 18:59:32 »
Hmm it's kinda expensive... Anything with NKRO over USB and PCB mounted in TKL. I played on a board with 6 key and constantly while flying a aircraft I ran out of keys... I don't have a PS2 port either  :-[
Offline sth
  • 2 girls 1 cuprubber
« Reply #13 on: Thu, 12 September 2013, 19:03:48 »
TKL: Neo Zelia
i've only ever been told the zelia is a piece of crap... but it looks really good.
Offline C5Allroad
« Reply #14 on: Thu, 12 September 2013, 19:41:57 »
It does look good but a lot people say it's not very good... Still looking for a TKL that is good and is PCB mounted.
Offline skuko
« Reply #15 on: Fri, 13 September 2013, 01:56:13 »
if you rule out the neo zelia, then i'm afraid your only solution is a custom phantom board (which is technically plate mounted, but has special cutouts in the plate allowing for switch modding.
those have to be assembled though and are quite pricy as well (or so i understood it).
« Reply #16 on: Fri, 13 September 2013, 14:39:32 »
All of the complaints I saw about the Neo, were on the first revision which apparently had **** wireless. Supposedly that was fixed on the newer revision. I don't see many other complaints about them other than should have been known before buying like the exposed PCB. MX is MX, the keycaps are the same as others from the same OEM, Plum and Noppoo. I never saw any negative remarks about wired function or it's fit and finish.
I don't own one, but I wouldn't be worried to buy one.
« Last Edit: Fri, 13 September 2013, 14:41:46 by IvanIvanovich »
Offline C5Allroad
« Reply #17 on: Fri, 13 September 2013, 17:41:36 »
Where can I buy a phantom board?
« Reply #18 on: Fri, 13 September 2013, 17:48:10 »
Phantom PCB plus you will need a plate, because it dosen't have mounts for stabilziers in the PCB, and a case of some sort that is Filco compatible, switches, keycaps, etc...
Offline C5Allroad
« Reply #19 on: Fri, 13 September 2013, 20:49:28 »
What plate can I remove the key stem and spring without soldering
Where can I find that one?
Offline C5Allroad
« Reply #21 on: Sat, 14 September 2013, 16:35:42 »
Hmm I'll see when I can spend money...
