Author Topic: Must-try Alps switches  (Read 25561 times)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Must-try Alps switches
« Reply #50 on: Mon, 16 September 2013, 12:57:14 »
How is the early Model M ping different from the late Model M ping?
Bore Awards
Offline ch_123
« Reply #51 on: Mon, 16 September 2013, 16:13:56 »
There's two factors - rivets, and backplate thickness and material. The really old ones are made from that same heavy-duty brass-coloured tempered steel as the Model F backplates are, newer ones are not that rigid (I was able to bend a Unicomp one with my hands, and my upper body strength is... lacking).
Not entirely related, but my 1985 Model M is almost painfully stiff to type on, and I've heard others say the same of their early Ms, although it's probably a case of YMMV.
« Last Edit: Mon, 16 September 2013, 16:18:39 by ch_123 »
Offline 1391406
« Reply #52 on: Mon, 16 September 2013, 19:15:21 »
I don't know that the ping itself really differs from late Model M's(Lexmark?), but it's relatively non-existent with current Unicomp's.
  • RIP
    • Boring twaddle
« Reply #53 on: Mon, 16 September 2013, 19:20:50 »
I know Unicomps barely ping — I used to think that was a good thing, but now I'm not so sure. I should take my Model M to the office and put some hours on it. I just need to forget that the Windows keys exist :( (really annoying with Server 2012, too)
Bore Awards
Offline 1391406
« Reply #54 on: Mon, 16 September 2013, 19:27:35 »
Any particular reason you're on the fence?
  • RIP
    • Boring twaddle
« Reply #55 on: Tue, 17 September 2013, 12:37:24 »
Just not sure whether I prefer a flat sound or a twangy sound. Or dry, or warm/resonant. Or a loud keyboard or a quiet one. It's probably something like: loud == fun, quiet == far less distracting (to me, not to others).
Bore Awards
