Author Topic: stretching springs?  (Read 1290 times)
Offline Jixr
stretching springs?
« on: Thu, 12 September 2013, 10:53:50 »
So I've a question,
is there any reason why I couldn't pop a switch apart, take the spring, and pull on it and stretch it out and that would give it a more stiff resistance?
( obviously its impossible to do a full board and make the rate consistant, but for a one off key? )
Offline Thimplum
  • Master of all Ponies
Re: stretching springs?
« Reply #1 on: Thu, 12 September 2013, 10:54:50 »
Why would that make it stiffer? I think that's bad for the spring.
TP4 FOR ADMIN 2013
« Reply #2 on: Thu, 12 September 2013, 10:57:20 »
The spring rate shouldnt change just because you stretch it out. Short term it might feel heavier but you'll either mess up the coils or the plastic deformation will sit the spring back into its original form
Offline Jixr
« Reply #3 on: Thu, 12 September 2013, 11:00:30 »
*takes apart clicky pen and pays with the spring*
yeah, i guess long term it would just go back to its original spring rate.
These are the things I think about when I'm at work all day.
Offline Thimplum
« Reply #4 on: Thu, 12 September 2013, 11:41:04 »
Mod Edit: Please don't derail threads, thanks.
« Last Edit: Thu, 12 September 2013, 11:49:14 by jwaz »
TP4 FOR ADMIN 2013
