Author Topic: I need help.please~about keyboard size and code  (Read 2859 times)
Offline Mine
« on: Thu, 12 September 2013, 19:03:26 »
i want diy a keyboard,i need a design size and code, i have ATmega32u4,so i need code ,but i don`t know how to code
Please look pic ,i `m a chinese ,so my english is bad, sorry,i think people can understand my idea
http://item.taobao.com/item.htm?spm=a1z0k.1000775.1.44.CKrK2Z&id=22040575322
http://item.taobao.com/item.htm?spm=a1z0k.1000775.1.81.CKrK2Z&id=16629933147
Offline Mine
Re: I need help.please~about keyboard size and code
« Reply #1 on: Thu, 12 September 2013, 21:10:17 »
Please... Anyone? :(
Offline Hellmark
« Reply #2 on: Fri, 13 September 2013, 09:33:19 »
Can you please quit reposting the same post? It is not likely to get anyone to help you.
Also part of the problem is you've picked a board that no one really uses. Most people go for the Teensy, and there are several different firmwares available for that. On something Arduino based, people around here would have to do something from scratch, and it isn't a quick undertaking, especially to do for some total stranger. Just because the two are a similar form factor and chipset, doesn't mean they're compatible.
As far as the key spacing, generally it is 19.05mm between keys. For the gap between the function row and the number row, well, that's kinda your preference. There are different files floating around for keyboard plates and PCBs, take a look at those.
Offline Mine
« Reply #3 on: Sat, 14 September 2013, 20:47:34 »
thinks~~ ;D i will try to
Offline Mine
« Reply #4 on: Sat, 14 September 2013, 20:51:51 »
i have a quesion,19.05mm?it is looks like no 19.05mm~~The distance is not too great,I use google translator
Offline Hellmark
« Reply #5 on: Sun, 15 September 2013, 00:50:41 »
Here's directly from the Cherry spec sheet for the MX switches
Standard lead spacing 19.05 mm
Try do some actual leg work on your own.
« Reply #6 on: Sun, 15 September 2013, 00:51:56 »
The deskthority wiki contains lots of information for designing your own keyboard
