Author Topic: I just found an AppleDesign Keyboard with NMB sliders  (Read 4261 times)
Offline legodt
« on: Sat, 14 September 2013, 00:51:22 »
What are NMB sliders like compared to other switches? Are they worth using or are they just junky rubberdomes with a sleek package? Is it worth cleaning this keyboard for daily use over my cherry brown board? How the heck would I convert this weird deprecated apple connector to USB?
Offline terran5992
  • One With The Cup Rubber
Re: I just found an AppleDesign Keyboard with NMB sliders
« Reply #1 on: Sat, 14 September 2013, 02:42:43 »
Id say its better than a rubber dome.
Perhaps you could get an adapter ?
« Reply #2 on: Sat, 14 September 2013, 03:07:01 »
« Reply #3 on: Sat, 14 September 2013, 08:42:56 »
The ADB cable requires a converter like the Griffin iMate.
My experience is that Design keyboards with detached cables have nice Alps-compatible keys, and the ones with attached cables do not.
If they do, keep the caps and throw the board away.
- D Trump 2026-10-24
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #4 on: Sat, 14 September 2013, 09:47:33 »
http://deskthority.net/wiki/AppleDesign_Keyboard — detailed shots of both the Alps and NMB versions.
Both of mine (one Alps, one NMB) have attached cables with a routing channel that I only just spotted. The switches suck, and the keycaps are of no use for anything.
I don't know of one with a separate cable — got a reference for that?
Bore Awards
« Reply #5 on: Sat, 14 September 2013, 10:55:31 »
No, I just know that I bought a couple like that at junk stores, kept the caps, and tossed the boards.
I had bought at least one of the good ones before I bought one with attached cable - I did not bother pulling a cap until I got home. Since then, I have examined several and only found one more detachable cable/Alps-compatible.
  • RIP
    • Boring twaddle
« Reply #6 on: Sat, 14 September 2013, 12:39:31 »
These ones with the detachable cable, were dome switches with Alps mount sliders?
Bore Awards
« Reply #7 on: Sat, 14 September 2013, 15:48:51 »
I believe so. It has been a while.
Offline legodt
« Reply #8 on: Sat, 14 September 2013, 16:15:37 »
Thank you all for the info. Back into storage with this one!
