Author Topic: POM vs PBT.  (Read 19420 times)
Offline Oobly
Re: POM vs PBT.
« Reply #50 on: Fri, 27 December 2013, 05:14:24 »
why do people care about toughness for keycaps?
Because they don't want their keycaps becoming shiny within weeks of usage. "Hard-wearing" would be a better word.
i wasn't talking about shining.  i was talking about crushing pressure.
So is POM a stronger plastic than ABS or PBT?
What exactly do you mean by "stronger"?
In terms of pure tensile strength, POM is strongest (68MPa), then PBT (50MPa), then ABS (40MPa).
However, there are different measures of "strength". Tensile strength, compressive strength, fracture resistance, surface hardness, etc. PBT has low fracture resistance for instance, even though it has higher tensile strength and surface hardness than ABS. This is why it doesn't handle being hit with a hammer as well as ABS like in that ridiculous Ripster hammer test image: http://deskthority.net/wiki/File:Hammer_Time_-_PBT_versus_ABS.jpg
In simple terms, POM is the "toughest" (highest tensile strength and fracture resistance). PBT is hard wearing, but brittle, ABS is the softest and it's fracture resistance is somewhere in between POM and PBT.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: POM vs PBT.
« Reply #51 on: Fri, 27 December 2013, 19:00:45 »
No idea.
Whatever tbc meant by "crushing pressure".
Offline yjfknt
Re: POM vs PBT.
« Reply #52 on: Fri, 27 December 2013, 19:09:18 »
I prefer PBT because of the texture and I dislike both ABS and POM textures I feel like they feel pretty similar.
Offline tbc
Re: POM vs PBT.
« Reply #53 on: Fri, 27 December 2013, 19:47:47 »
No idea.
keycap vs hammer.  or more likely, other packages on top of them when they're being shipped.
Offline lilky
Re: POM vs PBT.
« Reply #54 on: Fri, 27 December 2013, 23:57:32 »
I think each plastic material has it's own pros and cons. Try using different plastics with different switches...the combinations are endless!
