Author Topic: Filco keycaps on Poker 2??  (Read 2681 times)
Offline concept73
« on: Sun, 15 September 2013, 15:15:55 »
Evening all, just a quick one, does anyone have any experience with Filco mx's on a poker 2??
I say this because i can get these caps in the UK without having to import,
Any advice??
http://www.keyboardco.com/product/blank-black-filco-104-key-keyset.asp
Thanks in advance!
Poker 2 with reds
Soon to be a JD40 with reds
Re: Filco keycaps on Poker 2??
« Reply #1 on: Sun, 15 September 2013, 15:44:59 »
Poker 2 is cherry stabs, while Filco is costar.
The mods won't fit, but everything else will.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 15 September 2013, 15:55:38 »
What? Stabs have no bearing on anything. Filco set main 61key block will be 100% compatible.
« Reply #3 on: Sun, 15 September 2013, 15:58:33 »
Really?
Guess I'm wrong. Again.
Offline concept73
« Reply #4 on: Sun, 15 September 2013, 16:04:28 »
So the main keys will fit but mods wont?
Poker 2 with reds
Offline elton5354
« Reply #5 on: Sun, 15 September 2013, 16:07:36 »
All keys will work.  For the mods (shifts, space bar, enter, backspace), you just have to remove the white plastic from the bottom of the stems in order for them to fit properly into the Poker 2 stabilizers.
That is if you're pulling them off a Filco keyboard.  If you're just buying new key cap sets, they don't include any of that, so you can just plug and type. ;)
« Last Edit: Sun, 15 September 2013, 16:09:56 by elton5354 »
