Author Topic: FC660M review-ish  (Read 10922 times)
Offline wicked1
FC660M review-ish
« on: Mon, 16 September 2013, 13:49:51 »
Hello,
Been lurking a long time.. Thinking about getting a mechanical KB for years.
Initially I got a Filco full sized MX brown.  Great keyboard, but the brown switches were a bit too light for me.  It was a little loud, too, so I got o-rings for it, which I did like.
But, I wanted to try a firmer switch.  I got the leopold 660m with the MX Clears and love it!  I have no idea why I bough a full sized board the first time.  I though I'd miss the number pad, but not at all.  I do miss the enter key on the number pad, because I often used it while using the mouse.   Not anything to cause regrets, though.  The arrow keys are a need for me, so this is the perfect small keyboard.
About clear vs brown switches..  I mentioned the browns are too light for me, but it really depends on the type of typing I'm doing, or my mood.  It's easier to be quiet if I type carefully on the browns (as in at night w/ my girlfriend sleeping on the couch next to me).  I can see where the browns could be better for long term relaxed typing as well as skilled fast typing (I'm not that skilled).  The clears are a little too firm when I'm tired and have a lot of typing to do.   They are great though for normal typing and especially good for when I'm banging away typing as fast as possible.  I always bottomed out on the browns, but the clears, not so much.  They get firmer as you go, so it's easy to stop after the bump w/out bottoming out.  No need for the o-rings, either, because I'm not hitting the bottom.
To be honest I mostly joined so I could post a pic of my keycap decision and say thanks for all the advice I have indirectly gotten by reading the forums.
Re: FC660M review-ish
« Reply #1 on: Mon, 16 September 2013, 23:25:30 »
Welcome to Geekhack!
"I mostly joined so I could post a pic of my keycap decision" - you'll fit in well around here ;)
Another happy FC660x user.
Offline Steven
  • Formerly lowyatguy
« Reply #2 on: Thu, 19 September 2013, 21:15:03 »
Hello,
I do love my FC660M, the PBT surface is kinda rough and having a good solid feel to type on. Mine is with brown. :D
« Last Edit: Thu, 19 September 2013, 21:20:45 by lowyatguy »
LF: Duck Mini V1 aka Duck Poker Case
http://geekhack.org/index.php?topic=49840.0
KMAC Happy | Hammer Poker Titanium & Silver | Leopold FC660M | FILCO TKL White | Ducky 9008S2 Pink | Ducky 9008G2 Pro Dye Sub | Ducky YOTD
Offline Beca
  • what am i doing with my life
« Reply #3 on: Thu, 19 September 2013, 22:48:58 »
Hello,
Where did you purchase those colored blanks from? Are they the same keycap height as the default Leopold caps? Looks nice!
Offline Steven
« Reply #4 on: Fri, 20 September 2013, 02:11:53 »
Hello,
They are the keycaps set by Leopold for FC660M and I got them from china ebay www.taobao.com
Offline ideus
  • Björkö.
« Reply #5 on: Wed, 13 November 2013, 11:47:45 »
Considering to order a 660m, and I'd like to get some feedback from you.
What would you recommend to get? gray or black case, blue or brown switches?
On switch I am currently typing on reds, but considering blues. Main activity is writing reports like 9 hours per day. On case color I may order black or gray, I have black and beige original Cherrie sets and purple mods.
« Reply #6 on: Wed, 13 November 2013, 16:20:19 »
Ultimately it is up to you - it is you who will be using the keyboard for months, if not years to come.
Personally for so much typing I would consider whether the noise of blues would annoy anyone around me.  If so, get browns (or reds).  If not, get blues as the clicky feedback is great.
I also believe that purple mods go better with a black case.  YMMV.
Offline ideus
  • Björkö.
« Reply #7 on: Wed, 13 November 2013, 17:31:56 »
Thank you for the feedback and your opinion has reinforced my final decision:
Black case with brown switches. As you said, it is very personal, but feedback of fellow GHrs is always welcome. BTW I found a nice vote report on mechanical keyboards that helped me to decide the switch type:
[size=78%]http://mechanicalkeyboards.com/mechanical_switches.php[/size]
