Author Topic: New Dell AT101Ws $10  (Read 59968 times)
Offline fkeidjn
New Dells ?
« Reply #100 on: Sun, 14 December 2008, 03:27:42 »
Quote from: xsphat;14705
more about the Alps blacks. I still like them, but only after using them for a while. They feel kind of like really heavy Topres, so they might loosen up and be pretty nice, but for now I don't know.
All you need are the rubber dampers, and then you have an SGI keyboard.
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
Offline iMav
  • geekhack creator/founder
New Dells ?
« Reply #101 on: Sun, 14 December 2008, 07:29:12 »
Reminds me of these two threads on macrumors:
Tangerine Macbook
Orange iBook
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
New Dells ?
« Reply #102 on: Sun, 14 December 2008, 21:54:11 »
So after just two days, I had to switch out the Dell, even if just for a few days.
Offline ch_123
New Dells ?
« Reply #103 on: Mon, 15 December 2008, 05:36:22 »
I got myself a rather worn out AT102W a month ago, but I might take a chance with one of these considering that theyre new and cheap. I could even transfer the switches from the US layout one to my UK layout one if I was sufficiently bored :)
Offline itlnstln
New Dells ?
« Reply #104 on: Mon, 15 December 2008, 06:04:58 »
Quote from: fkeidjn;14715
You can't retro-fit the rubber dampers into a switch that doesn't have them already, unfortunately.  This is waht I am going to try to attempt in my Northgate mod (by switching the sliders out with those form an Apple 'board).
Offline lexicon
    • http://www.word-detective.com
New Dells ?
« Reply #105 on: Mon, 15 December 2008, 11:35:36 »
Is it possible to remove the dampers in an SGI board?  It would be cool to convert it to straight white Alps.  Alps switches seem pretty easy to get into from the top -- where is the bumper?
IBM Model M 1391401 (1989)
IBM Model M 52G9658 (1993) x2
Unicomp Customizer 101 (black)
Solidtek ASK-6600U
Dell AT101W (way too many)
Dell AT101W (black)
Silicon Graphics AT-101 (1993)
Cherry G84-4100
Offline itlnstln
New Dells ?
« Reply #106 on: Mon, 15 December 2008, 11:40:08 »
Quote from: lexicon;14884
Yes, It should be easy to remove.  See here:
http://park16.wakwak.com/~ex4/kb/tech_alps_bigfoot2.htm
If you do get rid of them, send them to me.  I will have to find sliders that will take them, but they should come in handy if some of the Apple ones I get are dry-rotten.
Offline wellington1869
New Dells ?
« Reply #107 on: Mon, 15 December 2008, 11:58:41 »
we need a rubber dampers "bank" ;)
using: ms 7000/Das 3
Offline itlnstln
New Dells ?
« Reply #108 on: Mon, 15 December 2008, 12:09:02 »
The biggest issue with it is needing the sliders to use the dampers.  It would have been nice if they would have used the same slider design across all the switches.  Then, production costs could have been cheaper and they would just add the dampers as necessary.  Oh well, it just makes modding that much harder.
New Dells ?
« Reply #109 on: Mon, 15 December 2008, 12:28:30 »
Quote from: itlnstln;14891
The  It would have been nice if they would have used the same slider design across all the switches.  Then, production costs could have been cheaper and they would just add the dampers as necessary. .
exactly, I'm surprised they didnt do that.
I guess thing to do is acquire a set of those sliders from an AEKII and keep them for life (xferring them into any new alps boards you get, as you go).
Offline itlnstln
New Dells ?
« Reply #110 on: Mon, 15 December 2008, 13:25:29 »
Quote from: wellington1869;14892
Pretty much.  I am not looking forward to doing the mod.  It is going to be a monotonous, tedious PITA.
Offline D-EJ915
New Dells ?
« Reply #111 on: Mon, 15 December 2008, 16:11:14 »
I got my 3 today (took long enough lol, ups).  Anyway the force needed to actually get the keys down is a lot lower than I'm used to except on the HHKB2 which is probably about the same or lighter.
« Last Edit: Fri, 20 November 2020, 18:44:11 by D-EJ915 »
Offline xsphat
  • Enlightened
New Dells ?
« Reply #112 on: Mon, 15 December 2008, 16:26:59 »
I took my Dell apart today, since I go the the new keys for the Topre, and it looks like I could hack off the number pad. I'm gonna see what I can do about getting the proper tools and I'll keep you cats posted as to whether I am going to attempt the mod.
Offline D-EJ915
New Dells ?
« Reply #113 on: Mon, 15 December 2008, 16:38:39 »
Quote from: xsphat;14945
sounds cool.
Are the keys always this difficult to pop off?  Granted I was using yo-yo string wrapped around either side of the switch under the key but dang.
Offline xsphat
  • Enlightened
New Dells ?
« Reply #114 on: Mon, 15 December 2008, 16:41:58 »
Alps keys are always a pain to get off.
New Dells ?
« Reply #115 on: Mon, 15 December 2008, 16:44:00 »
Quote from: D-EJ915;14946
use the "two paperclips" method.
Offline lowpoly
New Dells ?
« Reply #116 on: Mon, 15 December 2008, 16:44:38 »
Better saw the pcb somewhere outside, the dust is toxic. And if you use for ex. a Dremel there will be lots of dust.
Offline xsphat
  • Enlightened
New Dells ?
« Reply #117 on: Mon, 15 December 2008, 16:50:44 »
Quote from: lowpoly;14950
Better saw the pcb somewhere outside, the dust is toxic. And if you use for ex. a Dremel there will be a lot of dust.
Thanks for the tip. My biggest concern with the project is the two metal plates the PCB is sandwiched between. The rest should be cake.
Offline lowpoly
New Dells ?
« Reply #118 on: Mon, 15 December 2008, 16:58:06 »
IIRC, there's only one metal plate. The one on the back is just a piece of cardboard? Anyway, a Dremel would take care of everything in no time.
The most difficult part is probably getting nice cuts through the case. Hard to do without machinery. Maybe with a miter-box saw. I'd probably let a company do it with a milling machine. You can put little circular saw blades on those. You will have clean cuts and everything will fit nicely afterwards.
New Dells ?
« Reply #119 on: Mon, 15 December 2008, 16:58:53 »
Quote from: xsphat;14951
the metal plates are going to be a B**ch.
Cant you take it to home depot and have them cut it for $5 or $10?
They've done that for me with copper plumbing pipe and etc.
Offline xsphat
  • Enlightened
New Dells ?
« Reply #120 on: Mon, 15 December 2008, 18:59:43 »
lowpoly, there are two in mine — one on the top and one of the bottom.
Offline fkeidjn
New Dells ?
« Reply #121 on: Tue, 16 December 2008, 00:30:08 »
Would it be possible to chop off the excess plastic, to make it more like a Filco Tenkeyless?
Offline xsphat
  • Enlightened
New Dells ?
« Reply #122 on: Tue, 16 December 2008, 01:57:44 »
Maybe, but that would kill what the keyboard is - fugly!
And if I was to do that I would just build a new case. I want to modify the Dell (and get rid of that stupid logo), so that is a good idea, but not my intent.
Offline lowpoly
New Dells ?
« Reply #123 on: Tue, 16 December 2008, 04:21:51 »
Quote from: xsphat;14967
Oh, haven't seen that before (and I took a few apart). Does that mean you can't access the circuit side of the pcb? Because it's possibile that you cut vital paths when cutting off the numpad.
Offline cchan
New Dells ?
« Reply #124 on: Tue, 16 December 2008, 05:55:25 »
My AT101W has a metal plate on top, and a metallized cardboard one on the bottom. Could it be that xsphat is mistaking the metallized cardboard sheet for an actual metal plate?
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline iMav
New Dells ?
« Reply #125 on: Tue, 16 December 2008, 06:40:38 »
Quote from: Tales;14995
I'm sure xsphat's AT101W is the same as everyone else's.
Offline bigpook
New Dells ?
« Reply #126 on: Wed, 17 December 2008, 18:52:02 »
Got my Dell today, I take back the negative comments. Granted, its full size, but its new. Its even got that new keyboard smell : ) And the key feel is very nice.
New Dells ?
« Reply #127 on: Wed, 17 December 2008, 20:24:41 »
Quote from: bigpook;15175
wow, these have been a big hit huh? Mine is due in on the 22nd.
So I wonder how long an alps board lasts before turning into the gritty rattly monsters we've all experienced. "8 to 10 million keystrokes" is supposed to be the switch lifespan -- but how much is that in years? (assuming its one's main board).
Offline bigpook
New Dells ?
« Reply #128 on: Thu, 18 December 2008, 04:13:14 »
Quote from: wellington1869;15177
I will probably never find out. I doubt it will get used all that much. The gritty rattly monsters you mention is making me wonder. Do all alp switches degrade quickly? Or was/is it something else. I have a keyboard coming with white alps, will that the suffer the same fate?
Maybe I should have went with the blue cherries.
Offline xsphat
  • Enlightened
New Dells ?
« Reply #129 on: Thu, 18 December 2008, 04:42:02 »
Pook, it's just like everything else in life — you get back what you put out. My 20+ year old Northgate was smooth, as have been all the new Alps and the vast majority of my used Alps keyboards. Just take care of it the way you were going to anyway and you'll be fine.
Offline itlnstln
New Dells ?
« Reply #130 on: Thu, 18 December 2008, 05:58:59 »
Quote from: xsphat;15210
Exactly.  The ones Wellington and I got initially were stored in a fairly dirty and dusty location.  I spent about 10-15 min. taking them apart and bloeing them out with an air duster.  There was all types of dust bunnies and dirt flying out of there.  I think that was why the switches felt gritty.  I have had my Northgate for awhile, and, other than the switches loosening up a little with use, they fell just as smooth as when I got them.  When I do my mod on the Northgate, I am going to blow out the inside of each switch as I replace the guts to ensure they stay clean.
Offline bigpook
New Dells ?
« Reply #131 on: Thu, 18 December 2008, 06:56:58 »
Thanks for the context. I feel better now. : )
Offline itlnstln
New Dells ?
« Reply #132 on: Thu, 18 December 2008, 07:36:56 »
Quote from: bigpook;15214
And, sh*t, it's $10.  If the 'board sucks after a year or two of use, I still think that's a better deal than any other $10 'board on the market.  That's why I got 3. ;)
Offline xsphat
  • Enlightened
New Dells ?
« Reply #133 on: Thu, 18 December 2008, 11:24:25 »
They are nice keyboards.
Offline bigpook
New Dells ?
« Reply #134 on: Thu, 18 December 2008, 13:34:40 »
Quote from: itlnstln;15215
Well yes, thats true. I should have got a couple instead of one. It will be hard to find them again at that price in the future.
New Dells ?
« Reply #135 on: Thu, 18 December 2008, 13:53:00 »
Quote from: itlnstln;15212
that would explain it I guess. That makes me feel better about alps too.
Offline kodos96
New Dells ?
« Reply #136 on: Thu, 18 December 2008, 13:55:42 »
When I do my mod on the Northgate...
Not sure if you've already talked about it in another thread, but what mod(s) are you planning on your Northgate? (I'm assuming you're talking about the Evolution). As an Evolution owner with modding plans myself, I'm just curious what others are up to.
New Dells ?
« Reply #137 on: Thu, 18 December 2008, 14:03:42 »
Quote from: kodos96;15240
he's going to silence it completely by addressing each of the sources of noise on it: click, bottoming clack, topping clack, resonance.  :)
(using, respectively: black alps leaf, rubber dampers from AEKii, rubber dampers from AEKii, and sound absorbing anti-resonance pads.)
Is that about right itln?
New Dells ?
« Reply #138 on: Thu, 18 December 2008, 14:28:08 »
Quote from: webwit;15243
Now for the alternative solution ;) You know how those Model M's have those speaker grills with nothing behind them? I'm thinking about using it, in combination with the Sennheiser PX-300  noise-canceling headphones which I have. I'd need a small amplifier, and ideally it would not catch sound (reaction time..NC is better with continuous sounds) but be triggered by the keys, with, I guess, some pre-recorded sound. But that would be very difficult..
wow, now thats a mod! :)
Offline itlnstln
New Dells ?
« Reply #139 on: Thu, 18 December 2008, 14:58:37 »
Quote from: wellington1869;15241
10-4!
Offline kodos96
New Dells ?
« Reply #140 on: Thu, 18 December 2008, 16:12:58 »
Why the black leaf springs instead of just using the AEKii for everything? Are AEKii's leaf springs too clicky?
I like the feel of my the white's so much that I'm not sure I want to mess with the leaf springs (especially if that Dell I tried the other day was in fact black alps - I didnt like the feel of them at all). So I'm thinking I might try AEKii sliders/dampers but leave the white's leaf srpings - I think I could live with the click, if I could just eliminate the clack. But I'll have to find an AEKii first and see how it goes (if anyone knows where I can get an AEKii btw, please let me know).
Offline kodos96
New Dells ?
« Reply #141 on: Thu, 18 December 2008, 16:22:52 »
I had this same idea before (not for a keyboard, but for other noise-cancelling needs). But what I'm wondering is whether noise-cancelling works with free-standing speakers (as opposed to headphones). It seems like having the cancellation waveform come from a source not localized right by your ears might make it not work... my main source of scepticism is just that if this DID work, somebody would have done it already.... cause you could make a Get Smart "cone of silence" kinda thing, which would be so cool that, if it were possible, you'd expect someone to have already productized it, and have infomertials for it on late night TV....
Offline itlnstln
New Dells ?
« Reply #142 on: Thu, 18 December 2008, 16:25:04 »
The click is unnecessary in the Alps switches and just adds sound without adding much feel.  In a Model M, the click IS the actuation of the switch in that when the spring buckles and, thus, clicks, the hammer presses on the membrane.  On the Alps, the click is just the leaf slamming against the casing of the switch; the switch is activated by another mechanism.  I found a "parts only" AEKII on ebay for about $3.
Offline kodos96
New Dells ?
« Reply #143 on: Thu, 18 December 2008, 16:26:23 »
Quote from: itlnstln;15262
Well then what accounts for the difference in feel between whites and blacks?
Offline itlnstln
New Dells ?
« Reply #144 on: Thu, 18 December 2008, 16:36:25 »
Quote from: kodos96;15263
The minimal (IMO) difference in feel in balcks and whites has to do with the leaf snapping back on the casing of the switch.  See here:
http://park16.wakwak.com/~ex4/kb/tech_alps_bigfoot3.htm
Offline kodos96
New Dells ?
« Reply #145 on: Thu, 18 December 2008, 16:41:30 »
Quote from: itlnstln;15265
The Dell I tried the other day felt WAY different (in a bad way) than my Northgate (whites).... but I wasn't able to verify what keyboard that actually was... did Dell ever make any keyboards with non-membrane switches other than alps black?
Offline itlnstln
New Dells ?
« Reply #146 on: Thu, 18 December 2008, 16:43:30 »
The differences I feel between my Dells and my Northgate have to do more with the case of the keyboard (plastic vs. steel, respectively) than the switches.  To me, the switches, themselves, feel very silmilar aside from a little more snap in the tactile bump on the whites.
New Dells ?
« Reply #147 on: Thu, 18 December 2008, 19:11:36 »
any chance you can post before/after sound files?
New Dells ?
« Reply #148 on: Fri, 19 December 2008, 12:56:06 »
does anyone know if this dell (at101w) has alps or strongmans?
Offline itlnstln
New Dells ?
« Reply #149 on: Fri, 19 December 2008, 13:30:55 »
Alps.
