Author Topic: Change of keyboard's layout in Windows not affecting shortcuts?  (Read 3878 times)
Offline Piotr Dobrogost
« on: Thu, 19 September 2013, 16:10:31 »
I'm learning Workman layout but I noticed shortcuts still use the same physical keys they used in QWERTY.
How can I fix this so that shortcuts would be aware of currently active layout?
I'm on Windows and I created Workman layout using Microsoft Keyboard Layout Creator 1.4
After googling I found only this: http://www.daniweb.com/hardware-and-software/microsoft-windows/threads/272875/keyboard-layout-change-not-affecting-shortcuts
« Last Edit: Fri, 20 September 2013, 17:02:08 by Piotr Dobrogost »
Re: Keyboard Layout Change not affecting shortcuts?
« Reply #1 on: Thu, 19 September 2013, 17:27:29 »
Searching for Microsoft Keyboard Layout Creator shortcut did the trick. I found the solution at http://www.sensefulsolutions.com/2010/08/how-to-fix-keyboard-shortcuts-in-klc-eg.html I hope someone will find it useful.
Offline Oobly
« Reply #2 on: Fri, 20 September 2013, 02:35:31 »
Great find! I am sure this will be helpful.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline davkol
  •  Post Editing Timeout
Re: Keyboard Layout change not affecting shortcuts?
« Reply #3 on: Fri, 20 September 2013, 16:38:36 »
FWIW something similar can happen when using KDE Plasma Desktop Workspace. If you change the active layout on the go, shortcuts will still be mapped to the default layout. Maybe it has been fixed in some newer release. However, I think it could be a nice feature in case (a) you're adapting to a new layout, but you haven't had time to adapt your muscle memory for hotkeys and your productivity suffers because of that; (b) you're using some app with QWERTY-centric shortcuts (or Vim, heh); (c) someone changes you your layout as a prank.
« Reply #4 on: Fri, 20 September 2013, 17:00:02 »
Googling for qt shortcut keyboard layout bug brings many bugs regarding this both in KDE and in Qt itself.
Offline davkol
« Reply #5 on: Fri, 20 September 2013, 17:07:00 »
Half of them appear to be more about Qt widget layouts, though. I think this is what we're talking about.
Re: Change of keyboard's layout in Windows not affecting shortcuts?
« Reply #6 on: Fri, 20 September 2013, 17:07:28 »
It seems like there are other problems with shortcuts after changing layout - http://superuser.com/questions/282471/ctrlshiftf-not-working-in-putty-when-using-a-modified-keyboard-layout-on-win-7
