Author Topic: G84-4100... seller is high  (Read 5985 times)
Offline cchan
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline Chloe
  • Switch Kitten
« Reply #1 on: Thu, 04 December 2008, 07:19:05 »
scarry-garcia sells them at ridiculous prices too. You can buy them new for less.
Offline cchan
Offline skriefal
« Reply #3 on: Thu, 04 December 2008, 17:13:41 »
But... but... it's "vintage" and "hacker-style"! :)
Offline cchan
« Reply #4 on: Thu, 04 December 2008, 17:40:08 »
"Vintage" doesn't mean crap :P The seller sells boards with Windows keys as being "Vintage". XD
Offline skriefal
« Reply #5 on: Thu, 04 December 2008, 20:45:43 »
Exactly my point.  This is a perfect example of the misuse of terms like "vintage" to hawk an otherwise unremarkable item (unremarkable = good, but nothing to get overly excited about).
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #6 on: Fri, 05 December 2008, 19:20:23 »
Ooooh, "hacker style"!  Does it have a "crack password" key?
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline bhtooefr
    • bhtooefr.org
« Reply #7 on: Fri, 05 December 2008, 19:28:41 »
Last I checked, a "hacker style" keyboard clicks louder than a Model M, but clicks at completely different times from when keystrokes are entered, and sends keystrokes that are entirely different from what the act^W"hacker" is entering into the system, but are mysteriously always the correct command or password.
And, they're only attached to machines running MovieOS.
:p
