Author Topic: CPTBadAss' Razer Orbweaver Mod  (Read 50389 times)
Re: CPTBadAss' Razer Orbweaver Mod
« Reply #50 on: Mon, 01 May 2017, 08:16:55 »
Bump!
I can't use my Orbweaver until I get the ball bearing issue fixed. Please help.
The original poster of this thread is no longer active here.
I'm not sure if anyone else here has done any modifications on the orbweaver that can help you.
« Reply #51 on: Tue, 02 May 2017, 02:17:15 »
Hi,
Sorry to bump the thread but I need some help.
So I was trying to disassemble the thumb pad and see why it was moving, but when I did that the ball bearing dropped, fortunately I didn't lose it however I didn't see where it dropped from. Where and how exactly am I supposed to put the ball bearing back in?
Thanks in advance!
I feel like it should be pretty obvious where a ball bearing goes...
Maybe some pictures would help.
Offline -Karakurt-
« Reply #52 on: Wed, 03 May 2017, 11:51:16 »
No it's not, but I eventually figured out where it goes, it should sit in a hole/channel however managing to sit the ball back to its place without having to diassemble the whole thumb part can be a pain in the arse, because it constantly drops.
