Author Topic: GMK white/dark grey US/GB full set + 'Gamer' add-on {Closed}  (Read 369179 times)
Offline GeorgeK
Re: GMK white/dark grey and black multilanguage sets
« Reply #500 on: Tue, 17 December 2013, 01:23:25 »
Damn I need to reread this thread!  I'm lost on the new set options!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #501 on: Tue, 17 December 2013, 09:29:21 »
I will clean it all up real soon, or probably better yet lock this thread up and start a new one.
So... I got initial quote on the full white on grey mono unified set. How does €88 / $122 sound? It's not as low as I would have liked, but it is still about $40 cheaper than the current base+mods+nav.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #502 on: Tue, 17 December 2013, 10:34:34 »
Sounds good to me! I think that will have a lot more luck in the new year.
Offline domoaligato
« Reply #503 on: Tue, 17 December 2013, 10:44:19 »
That sounds great for a large complete set.
« Reply #504 on: Tue, 17 December 2013, 10:55:56 »
I would buy that.
Offline LechnerDE
« Reply #505 on: Tue, 17 December 2013, 12:13:10 »
Sounds very good!
I will be in - as in all you GBs ;)
If you offer it in January people will have some christmas money and a fresh keyboard budget for 2014!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #506 on: Tue, 17 December 2013, 22:47:24 »
YES, a nice and fresh Keyboard Budget for 2014  :thumb: .  Looking forward to this new year, some really good key-sets are coming down the line.
Offline bazh
« Reply #507 on: Tue, 17 December 2013, 23:44:35 »
And if you make it to Febuary, people that celebrate Lunar New Year like us would appreciate much :P
HHKB Pro2 white
Newbie again
Offline Elrick
  • Hype Master
« Reply #508 on: Wed, 18 December 2013, 04:27:42 »
And if you make it to Febuary, people that celebrate Lunar New Year like us would appreciate much :p
Just hope that Ivan gets the MOQ required, because currently the poor guy is failing to meet any 400 levels just yet on any orders.  GMK key-caps are a delight to type with and currently using them on my LZ-GH keyboard, pure god-like usability  :thumb: .
Offline bazh
« Reply #509 on: Wed, 18 December 2013, 04:40:22 »
yep, I'm using my Olivetti set on LZ-CE  :p GMK keycaps are so great that I don't try SP no more  :p
HHKB Pro2 white
Newbie again
« Reply #510 on: Wed, 18 December 2013, 12:51:25 »
Well due to the MOQ I am not sure about any deadline. Will probably just have to be a it closes when we reach that affair.
Offline Elrick
  • Hype Master
« Reply #511 on: Wed, 18 December 2013, 16:53:45 »
I hope you do get the required MOQ because this one you've come up is JUST perfect with any other colours (if need be) on any CherryMX switched keyboard ever made or will ever be made in the future (if that makes sense).
PLEASE I hope the majority here see the potential of these on their keyboard(s) because it's totally sublime having these installed and used every day of the week.  GMK made key-caps are truly worth the money.
I know I'm an SP wh0re spending all my money on their key-caps (like most cap-addicts) but GMK is the Mercedes Benz/Bentley/Rolls-Royce of key-caps, that are currently available to people world-wide and should be purchased no matter what.
« Last Edit: Wed, 18 December 2013, 16:59:50 by Elrick »
« Reply #512 on: Wed, 18 December 2013, 17:03:00 »
Yes exactly my thoughts as well, it would be a very nice neutral set to mix with any white on color mods/smaller packs that currently exist or may be done in future.
« Reply #513 on: Fri, 20 December 2013, 12:21:34 »
Here is new simplified €88 set. It will be all white on dark grey
I am still waiting revised quote for simplified extras (generic pack) add on and additional white/black mods/nav/fun simplified.
« Reply #514 on: Fri, 20 December 2013, 12:26:40 »
Is this dark grey the same color as dolch mods still?
« Reply #515 on: Fri, 20 December 2013, 13:01:47 »
Yes same dark grey as Dolch modifiers.
Offline gojira54
« Reply #516 on: Fri, 20 December 2013, 13:59:23 »
Looks great, hope it gets those 400 orders as quickly as it deserves
 :thumb:
« Reply #517 on: Fri, 20 December 2013, 14:01:34 »
Really nice looking, GJ Ivan.
« Reply #518 on: Fri, 20 December 2013, 14:52:19 »
I can't remember what the profiles are and I don't have the board in front of me right now, but will this accommodate an 1800 layout fully, with correct profiles for the cluster above the numpad?
Offline LechnerDE
« Reply #519 on: Fri, 20 December 2013, 15:26:15 »
Good job on the new budget set Ivan!
These will go well with many different keys so there should be one combination for everybody  :thumb:
I am definitely in - do we have to submit a new order or does the existing one count as one set?
If we can't reach MOQ on that, then I only see Massdrop as our last hope...
« Reply #520 on: Fri, 20 December 2013, 15:38:48 »
You could use set on winkeyless 1800, with blanks for the NAV section. Del, end, pg dn only come in D row and there is no 1x Ctrl/Alt or 6x spacebar. Those keys may make it into the Generic/Alternates add on when I get that revised to replace the now redundant extra function row.
If you already ordered BASE, then you have an order in for the new full set.
« Last Edit: Fri, 20 December 2013, 15:44:25 by IvanIvanovich »
Offline keymaster
  • Topre Revolution Theorist
« Reply #521 on: Fri, 20 December 2013, 15:53:57 »
Will this be in white on black?
« Reply #522 on: Fri, 20 December 2013, 16:05:05 »
Yes, there still option to buy white/black mods, nav and function separate. It's going to be cut down a little, remove some of the duplicate caps locks and things.
Offline keymaster
« Reply #523 on: Fri, 20 December 2013, 16:15:36 »
It would be nice to have the  R4 caps lock as it's the main reason I'd be purchasing the mod pack. I switch 'Caps Lock' and Left 'Control on my RealForce, so it would be nice to be able to have the keycaps for MX.
« Reply #524 on: Fri, 20 December 2013, 16:22:04 »
Don't worry, those stay. I mean there will only be one each row C left, not 2. Only things that will have 2 of same left will be Control and Windows.
Offline ideus
  • Björkö.
« Reply #525 on: Fri, 20 December 2013, 16:25:28 »
Excellent! I will be definitely in for that cheaper mods set. When do you think it will be posted?
« Reply #526 on: Fri, 20 December 2013, 16:42:41 »
I will post whenever I get pricing update for the revisions.
Offline ideus
  • Björkö.
« Reply #527 on: Fri, 20 December 2013, 17:18:42 »
Of course. I was just wondering when are you expecting to get an answer from them. But we should wait though.
Offline rindorbrot
« Reply #528 on: Sat, 21 December 2013, 03:36:47 »
I guess if we are lucky the price update comes at Monday. If not, then probably only in January...
Offline Irisviel
« Reply #529 on: Sat, 21 December 2013, 04:18:15 »
great update!Ivan...So odered again!
« Last Edit: Sat, 21 December 2013, 04:21:02 by Irisviel »
Offline simkev
« Reply #530 on: Sat, 21 December 2013, 04:21:09 »
It would be nice if the "MODS" kit could include two black spacebars (6.25u and 7u) or if you could add the option to order just spacebars like it was done in the Retro DSA groupbuy.
I need spacebars!
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
Offline Broadmonkey
« Reply #531 on: Sat, 21 December 2013, 05:40:58 »
Spacebars is probably the one thing I want the most! SP's DCS sucks and it's pretty hard and expensive to get 6.25 Cherry spacebars from old donor boards.
Offline Elrick
  • Hype Master
« Reply #532 on: Sat, 21 December 2013, 06:56:12 »
Also don't forget to let us know if you need to delete the old orders for us to re-pick the NEW orders again.  Or has that changed now?
Offline justnits
« Reply #533 on: Sat, 21 December 2013, 08:34:40 »
ivan, Y U DO DIS TO MY WALLET!
the full set is looking awesome at an amazing price with padlock symbol capslock and windows 8 logo!  ;D :thumb:
though some question about some of the mod keys whether this are the final design layout.
mainly the Scroll Lock and Num Lock. Num Lock has a down arrow symbol and windowed, whereas Scroll Lock is full text and not windowed?
and the Insert button's character...i couldn't think of how it's related to Insert >.<
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
« Reply #534 on: Sat, 21 December 2013, 11:12:15 »
I will move black spacebars into the white/black mods+ package.
I will replace items so they still match order form, but one can always resubmit as they wish if they are unsure once all items have been updated.
Scroll lock will get windowed too. The insert and delete that will be used is found on some older keyboards, and is 'ISO international standards'
Initially the delete a/ legend couldn't be located but it has been found so it will be that instead of the incorrect backspace <x] legend.
Offline justnits
« Reply #535 on: Sat, 21 December 2013, 11:18:00 »
alright, thanks for clearing that up!  :thumb:
Offline Halvar
« Reply #536 on: Sat, 21 December 2013, 14:33:50 »
They have that as a doubleshot legend? Awesome! I love these graphical legends, and delete is one of the nicest.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #537 on: Sun, 22 December 2013, 09:47:45 »
Do you have winkey 1x white legend on black in the future?
« Last Edit: Sun, 22 December 2013, 10:05:53 by quochung1989 »
« Reply #538 on: Sun, 22 December 2013, 09:57:15 »
Hard to say what will be done in future. Need to get this and the mini packs sorted out first.
  • Frenzy Classic.
« Reply #539 on: Sun, 22 December 2013, 10:07:28 »
Can't you add in mods kit?
« Reply #540 on: Sun, 22 December 2013, 10:12:22 »
I see, you had the colors switched around when you ask initially. Yes the 1x Windows key will be include in both since it available now.
Offline korrelate
  • iubeo stultum esse libenter
« Reply #541 on: Sun, 22 December 2013, 20:25:42 »
I can't even remember what the previous base kit looked like, but I have this idea that it was not as complete as the new base kit, am I right?
Also... any chance of getting a mock-up of these? The way that the shading turns out on these renders isn't making this look nearly as good as I think it will in RL & a good mock up ought to be able to sell a sh*t load of the base sets.
Topre REALFORCE
Offline gojira54
« Reply #542 on: Mon, 23 December 2013, 03:37:16 »
Forget mockups etc
Offer free random colour spacebars and it will hit MOQ  :p
Offline babyface
« Reply #543 on: Mon, 23 December 2013, 04:07:04 »
Hey Ivan, as a relatively new member here, can you tell me if 7x space bar is included along with 1x key that would be suitable for the bottom row of popular Korean customs? I can't tell just by looking at the pictures. Ta!
Where do you get the idea that an LZ-GH is basically a filco??
« Reply #544 on: Mon, 23 December 2013, 06:49:56 »
Forget mockups etc
You mean like the other GMK group buy is offering?
« Last Edit: Mon, 23 December 2013, 08:47:54 by SpAmRaY »
Offline bazh
« Reply #545 on: Mon, 23 December 2013, 08:19:02 »
I just feel like the base set was a little too pricey for a full mono tone set :(
HHKB Pro2 white
Newbie again
« Reply #546 on: Mon, 23 December 2013, 10:42:54 »
Base set used to only be the letters and numbers for US/GB layout. No mods, nav, function was include.
Yes it have 7x space and 1x win keys include as base set. Base should accommodate most popular 60%, tenkeyless and fullsize keyboard. Other keyboard should be taken care of with additional add on pack.
Full set isn't going to get any cheaper than this while keeping so much compatibility.
Offline pix3l_fodder
« Reply #547 on: Mon, 23 December 2013, 15:23:17 »
Still using the orders from before? could my order be changed to the new layout that you just posted and remove all the others! Cheers!
Re: GMK white/dark grey US/GB full set
« Reply #548 on: Wed, 08 January 2014, 16:04:26 »
I would like to try and get this moving again. I have streamlined this buy to be ONLY the white/grey full set... and an additional add on for some extras that is TBD on contents.
So where did the white/black stuff go? I will kick that off separately soon along with blank barebones patch kit, EDox patch kit and more.
Offline gojira54
« Reply #549 on: Wed, 08 January 2014, 16:07:25 »
This is easily the best GB I have seen since joining GH...
I'll go for two sets - really want this to make it
