Author Topic: Is it possible to change keys razer blackwidow tournament?  (Read 3260 times)
Offline xeon123
« on: Fri, 20 September 2013, 16:00:54 »
Is it possible to change the order of the keys in the razer blackwidow tournament to go from qwerty to dvorak layout?
How it sounds this keyboards with o-rings.
« Last Edit: Fri, 20 September 2013, 16:16:26 by xeon123 »
Offline phx
Re: Is it possible to change keys razer blackwidow tournament?
« Reply #1 on: Fri, 20 September 2013, 16:19:08 »
can be easily done thru a software, but you wont be able to swap the caps since they are different rows/heights.
Offline xeon123
« Reply #2 on: Fri, 20 September 2013, 17:21:46 »
And this keyboard has USB Passthrough?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Fri, 20 September 2013, 17:40:49 »
yes
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline ynrozturk
« Reply #4 on: Sat, 21 September 2013, 01:23:31 »
It doesn't have a USB pass through. Only one USB port at the back, which is for power. I own one.
You can change the keys to whatever you want in Synapse. Too bad that Synapse is a piece of **** most of the time and loves disconnecting for no reason. The latest update seems to have helped though in all fairness.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline xeon123
« Reply #5 on: Sat, 21 September 2013, 03:38:05 »
Do you advise me buying this keyboard, or a Leopold keyboard, or a KBT pure are much better?
I spend all day in the computer, every day... And I use a ruber dome keyboard. At the end of the day my hands are tired and the muscles are sore. Is it really true that the MX blues are much better for writing and less tiring?
« Reply #6 on: Sat, 21 September 2013, 03:53:38 »
Do not get the BlackWidow - there are so many reports of problems with them.
Leopold is good, but depending on which one you get you might have trouble getting replacement keycaps, or at least finding a replacement space bar.
Offline xeon123
« Reply #7 on: Sat, 21 September 2013, 04:10:25 »
For a newbie in mechanical keyboards like me, which mechanical keyboard you advise me?
I am a person that is programming and writing all day, do you advise me MX blues?
Offline llovro
« Reply #8 on: Sat, 21 September 2013, 04:12:38 »
get a switch tester from wasdkeyboards. That way you will find out which switch suits you the best. Also what's your budget?
« Reply #9 on: Sat, 21 September 2013, 04:12:51 »
Just programming and writing - MX blue would be good, if you don't mind the audible feedback (the click as you press each key).
If you don't need the numeric keypad, consider getting a TKL (tenkeyless) board - they are slightly cheaper and replacement keycap sets are also slightly cheaper.  Plus they free u pa little bit of desk space so your mouse can be a little closer to the centre of your body, which is fantastic!
Go for a CM QFR if you don't want backlighting, or a Ducky Shine (TKLs coming out soon) if you want backlighting.
There are a few others - KeyCool is also popular, but not as easy to get.  A 60% layout (e.g. Leopold FC660M) might be a bit of a shock if you are used to separate function keys.
