Author Topic: Regaining Control: A Story of Redemption  (Read 2946 times)
Offline pixel5
    • pixel5
« on: Fri, 20 September 2013, 17:55:31 »
So you might have seen me post in the Poker picture thread a little while back where I did an LED mod on my Poker II. If you didn't catch it the first time, I really jacked up the left control LED pads and got junk stuck in there (my first soldering experience). So for a while I've just had an incomplete LED design. Well I just got a new soldering station with a very small, precise tip (<3 jdcarpe) and decided to try and redeem myself.
As you can see, I destroyed it before.
And I just had no LED on that switch.
I had to actually use a crap ton of solder to make a solder-bridge across the two pads so I could heat both at the same time and I pushed the LED through a little at a time while heating it. Eventually, success!
What's even more awesome, is that I didn't have to jump it to the left-shift LED pads like I did the switch adjacent to it. Turns out the Poker 2 pads are through-hole, so the connection was still made on the flip side of the PCB. No jumping needed!
Redemption!
Poker II
Quickfire Rapid
BUY MY CRAP
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Regaining Control: A Story of Redemption
« Reply #1 on: Fri, 20 September 2013, 19:16:18 »
love it!
HUGE thanks to jd for picking up the tab for this fellow's new yihua :D
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Fri, 20 September 2013, 19:33:23 »
Nice touch with the Texas state flag.  That's real clean.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #3 on: Fri, 20 September 2013, 21:32:42 »
I loving the Texas flag. Nice work!
HHKB Pro 2   SmallFry Keyboard
« Reply #4 on: Fri, 20 September 2013, 21:38:26 »
very slick :)
Offline MKULTRA
  • telling it how it is
« Reply #5 on: Sat, 21 September 2013, 01:08:50 »
Jd is such an awesome dude.
