Author Topic: keycap cover?  (Read 2045 times)
Offline mv_LaiN
keycap cover?
« on: Sun, 22 September 2013, 02:00:43 »
i personally remove a few keycaps for gaming, but having the bare exposed switch is kind of ugly/sucks.. is there any low profile, simple cover that fits like a keycap? thanks
looking for cheap/used 60% boards! <3
Re: keycap cover?
« Reply #1 on: Sun, 22 September 2013, 02:41:04 »
Um, keycaps?
Or you could try to get the top half of a buckling spring keycap that would probably fit over an MX switch housing.
Re: keycap cover?
« Reply #2 on: Sun, 22 September 2013, 17:35:00 »
Or something like this perhaps?
Offline Tym
Re: keycap cover?
« Reply #3 on: Sun, 22 September 2013, 17:40:01 »
Don't SP make those keys that done work?
Offline Austin Powers
Re: keycap cover?
« Reply #4 on: Mon, 23 September 2013, 00:16:35 »
Not sure it will able to sit under them, but for cherry profile keycaps is 9mm cmiiw. Meh, I just leave it here if anyone wants to see it.http://elitekeyboards.com/products.php?sub=access,roofs&pid=rfek
