Author Topic: What Keycaps?  (Read 4702 times)
Offline uzoc
What Keycaps?
« on: Sun, 22 September 2013, 10:45:15 »
Just found this keyboard (no name).
Forgive how dirty it is (and dog hair):
36422-0
I know they are rubber dome, lasered.
I once had a HHKB Lite 2 and I think the keycpaps were the same (correct me if I'm wrong).
Any keyboard which might use these?
Offline ComradeSniper
  • HHKB Pro
Re: What Keycaps?
« Reply #1 on: Sun, 22 September 2013, 12:52:02 »
That's just a generic rubber dome keycap,  Topre caps are different.
Re: What Keycaps?
« Reply #2 on: Sun, 22 September 2013, 12:57:39 »
the hhkb lite does not use topre switches. it is also a rubberdome
Those look like the keycaps I had in my logitech that I threw away recently. Check if the F&J ones are any different or rotated or something.
I don't think they'll work in an hhkb lite2, but I dot have one on hand to check.
Offline uzoc
Re: What Keycaps?
« Reply #3 on: Sun, 22 September 2013, 23:44:30 »
I'll check it out...
This is what it looks like: http://fooninja.net/2010/07/29/cleaning-a-happy-hacking-keyboard/
Not worth anything?
Idea: The rubber domes can be used as keycap o-rings, I guess?
  • HHKB Pro
Re: What Keycaps?
« Reply #4 on: Sun, 22 September 2013, 23:58:25 »
Whoops, I had just woken up when I typed that and I read right over the lite part. In that case I don't know.
« Last Edit: Mon, 23 September 2013, 00:00:07 by ComradeSniper »
Offline BlueBär
Re: What Keycaps?
« Reply #5 on: Mon, 23 September 2013, 02:47:23 »
Not worth anything?
Even if those were compatible with the HHKB Lite I don't think you would get much out of them, there's no real demand for rubberdome keycaps.
If you cut them just the right size you could use them as o-rings, but good luck with that...
Offline uzoc
Re: What Keycaps?
« Reply #6 on: Mon, 23 September 2013, 10:29:06 »
Not worth anything?
Thanks, yeah, so wasteful...
And I got two of the same.
Now I understand why we must recycle...
