Author Topic: IBM 42H1331 and 82G3292  (Read 5753 times)
Offline Chloe
  • Switch Kitten
« on: Tue, 09 December 2008, 08:54:25 »
These are new POS keyboards with RJ11 connector. I don't know if they're buckling spring. The seller said the keys click when pressed. If this was a UK auction I'd snap one up to see if it could be converted to PS/2 or USB: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=140187589778
They're also selling brand new Spanish layout Lexmark Model Ms:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=140247411886
Offline Busty
« Reply #1 on: Tue, 09 December 2008, 09:54:58 »
The POS keyboards look like M2s. If that is the case they have BS.
Offline itlnstln
« Reply #2 on: Tue, 09 December 2008, 09:57:38 »
I wonder if you could just re-solder a ps2 cable to the PCB on the POS M2s.
Offline Chloe
  • Switch Kitten
« Reply #3 on: Tue, 09 December 2008, 10:04:10 »
That's what I was hoping. I read somewhere that you can fry the motherboard if you wire up a PS/2 connector incorrectly. I don't know if this is true, but +v and ground should be easy to determine.
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Tue, 09 December 2008, 10:33:59 »
IIRC, there are rubber dome M2s...
Offline Chloe
  • Switch Kitten
« Reply #5 on: Tue, 09 December 2008, 10:45:24 »
Thanks bhtooefr. :)
Offline xyzzy
« Reply #6 on: Tue, 09 December 2008, 11:05:55 »
Quote from: itlnstln;13995
Or build an adapter.
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
