Author Topic: G80-1306 HAU/00  (Read 2187 times)
Offline czarek
  • Keep the momentum going!
    • FalbaTech
G80-1306 HAU/00
« on: Tue, 24 September 2013, 08:05:49 »
Another goodie just came to me. Check this out - flashback to 1990, Made In West Germany, very unique layout, of course vintage blacks and thick double shots. I love those keys :)
Unfortunately it's devastated. Cable has been cut off and there was some loose electronics (resistors) shaking inside the case...
36667-0
36669-1
36671-2
Re: G80-1306 HAU/00
« Reply #1 on: Tue, 24 September 2013, 08:18:39 »
That layout is awesome and considering all the other damage, the case and caps look like they're in great condition.
Re: G80-1306 HAU/00
« Reply #2 on: Tue, 24 September 2013, 08:21:06 »
I'm sure it can be fixed ;)
Offline pasph
Re: G80-1306 HAU/00
« Reply #3 on: Tue, 24 September 2013, 08:27:57 »
Offline ch_123
Re: G80-1306 HAU/00
« Reply #4 on: Tue, 24 September 2013, 08:43:07 »
If I ever get my hands on a VAXstation or Alphastation, I'll probably try and hunt down one of those keyboards.
Offline Parak
Re: G80-1306 HAU/00
« Reply #5 on: Tue, 24 September 2013, 08:43:43 »
Whee, DEC VT220 layout.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: G80-1306 HAU/00
« Reply #6 on: Tue, 24 September 2013, 16:19:55 »
It's a terminal keyboard, and I'm not sure which protocol it speaks, but it's not AT. It would have originally had an RJ11 connector. To use it on a PC it would need a controller replacement or capable converter box. I had one of these and I just parted it out saving only the switches and keycaps.
Offline Dubsgalore
Re: G80-1306 HAU/00
« Reply #7 on: Tue, 24 September 2013, 16:21:08 »
That's very, very cool
Those blanks are awesome
