Author Topic: Aluminum case for QuickFire TK?  (Read 2744 times)
Offline RedPanda98
« on: Tue, 24 September 2013, 13:31:15 »
Does anyone know if there is a aluminum case for the QuickFire TK?
I know there's one for Filco TKL but also supports QFR.
Re: Aluminum case for QuickFire TK?
« Reply #1 on: Tue, 24 September 2013, 13:32:24 »
There isn't one. The TK is an odd/non-standard shape and it's not very popular.
Offline RedPanda98
« Reply #2 on: Tue, 24 September 2013, 13:39:23 »
That's a shame. It would be really awesome if someone made one. I'd actually buy it.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Tue, 24 September 2013, 13:42:42 »
Yeah probably won't happen, usually only the super popular ones gets custom aluminum cases.
Examples:
Poker / Poker 2
Filco Tenkeyless (Most of the time can also fit or mod to fit QFR)
Once in a long long while Filco Full Size
Outside of those I can't think of any aluminum case aside from the Korean customs, but those are standalone case not meant to be used on stock keyboards.
« Reply #4 on: Tue, 24 September 2013, 13:43:46 »
You'd be better off getting a phantom and using the all the keys on the right side.
Something like this.
36717-0
« Reply #5 on: Tue, 24 September 2013, 13:43:59 »
You could always make your own RedPanda98 ;). There's plenty of people around who can help you design it.
« Reply #6 on: Tue, 24 September 2013, 13:47:34 »
Mine would support it with the proper plate and top piece but it costs a lot to make.
« Last Edit: Tue, 24 September 2013, 13:49:50 by Photekq »
Offline RedPanda98
« Reply #7 on: Tue, 24 September 2013, 13:51:31 »
I need to get blocks of aluminum and a CNC machine :D
I could start a small business!
