Author Topic: Need a silent, well made mouse pad without ugly graphics  (Read 14516 times)
Offline dante
« on: Wed, 25 September 2013, 13:52:51 »
Subjects says it.  I've found a large variety of mousepads in many different materials but they all have ugly graphics.  I'm looking for something for a corporate environment.
Any ideas?  :thumb:
Re: Need a silent, well made mouse pad without ugly graphics
« Reply #1 on: Wed, 25 September 2013, 13:53:46 »
The Artisan mousepads? Or the SteelSeries QCK+ and you can cut off the logo?
Offline vun
  • Just one more thing
« Reply #3 on: Wed, 25 September 2013, 14:46:29 »
Mionix pads have minimal branding, Ulti-Mat pads also have very little branding. Quick search doesn't turn up anything with less branding until you get up to deskpad size. There are a few deskpads which have very little, or no, branding.
Offline hcry4
  • HHKB Hoarder
« Reply #4 on: Wed, 25 September 2013, 15:03:30 »
I second the Artisan mouse pads.
Offline dante
« Reply #5 on: Wed, 25 September 2013, 15:22:57 »
I'm going to give the Artisan Hayate a spin, thanks guys!
Offline Emospence
« Reply #6 on: Wed, 25 September 2013, 21:14:33 »
Steelseries QcK series?
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
« Reply #7 on: Wed, 25 September 2013, 21:41:06 »
I like my XTrac FatPad.  Not sure if that counts as without graphics.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #8 on: Wed, 25 September 2013, 23:51:40 »
I 3rdly recommend Artisan intensely  ;) .  Brilliant product range.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #9 on: Thu, 26 September 2013, 09:47:29 »
Personally I think Artisan Shiden looks really really nice, only drawback is that it seems to cause cursor jump on my Naga (Philips Twin Eye Sensor).  But doesn't seem to cause any issues on my other mice though.
:P
Though Hien and Hayate would probably be compatible with more other mice.  But you can feel the slight speed difference in horizontal and vertical.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #10 on: Thu, 17 October 2013, 09:00:48 »
Get a Microsoft mouse.
  • Live long and prosper
« Reply #11 on: Thu, 17 October 2013, 09:02:54 »
That won't help him considering he's looking for a mousepad...
tp thread is tp thread
« Reply #12 on: Thu, 17 October 2013, 09:03:44 »
Fine. Then get a Microsoft mousepad.
« Reply #13 on: Thu, 17 October 2013, 09:04:43 »
« Reply #14 on: Thu, 17 October 2013, 09:05:30 »
Better.
Of course it's better! Microsoft mousepads are always better. They reign supreme in the kingdom of mousepads.
Offline Grendel
« Reply #15 on: Thu, 17 October 2013, 17:45:40 »
Wowpad. Cheap, fits everywhere, gets the job done well.
- I'm game !
Offline Elrick
  • Hype Master
« Reply #16 on: Thu, 17 October 2013, 18:31:58 »
Damn, you're Microsoft worship is equally proportional to my hatred of Razer.  Amazing.......we almost think alike, except for the adoration part  :thumb: .
Offline xandr
« Reply #17 on: Fri, 18 October 2013, 01:32:48 »
I have a Artisan Shiden-Kai (large, x-soft, strawberry and milk) and absolutely no issues with my Naga 2014. From my understanding it still has the philips sensor of earlier models.
Anyway OP, I approve of your decision to go with an Artisan pad - they rock!
(if only they were available in more colors)
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline Emospence
« Reply #18 on: Fri, 18 October 2013, 02:06:38 »
The artisans are so plain and yet somehow manage to look so sweet.
Can't wait for mine to arrive.
Offline Elrick
  • Hype Master
« Reply #19 on: Fri, 18 October 2013, 03:51:17 »
Well I've gone off mine because I prefer the FUNC 1030 to Artisan.  Simply because I'm not a soft pad type of guy.  It's gotta be hard and nothing else, because the heat of the mouse builds up in a soft pad as you fling it around but with the 1030 it just glides across so easily with no friction.
With the Soft pads you always need to apply KY all over the base of your rodent just to move it around furiously  ;D .
Offline Emospence
« Reply #20 on: Fri, 18 October 2013, 04:08:33 »
And I prefer soft ones! Feels smoother.
Different strokes for different folks :)
Offline ComradeSniper
  • HHKB Pro
« Reply #21 on: Sat, 19 October 2013, 00:40:56 »
I want to give the Artisan Hayate a try but that's quite a bit of money for a mousepad. I will probably cave in a few weeks and buy it anyway but for now I'm going to try out a Qck.
Offline PointyFox
« Reply #22 on: Sat, 19 October 2013, 00:47:16 »
Get a Artistic Krystal View desk pad from Staples.  Much larger than "mouse pads" and they don't wear out.
Offline Badwrench
  • ummmm.....I forgot
« Reply #23 on: Sat, 19 October 2013, 01:00:56 »
Problem solved  ;)
I use one of these at work.   Very comfortable after you get used to it.
  http://www.newegg.com/Product/Product.aspx?Item=9SIA30R13R9114
Offline Elrick
  • Hype Master
« Reply #24 on: Sat, 19 October 2013, 18:38:00 »
Problem solved  ;)
I had one of those years ago, it was just too small.  The so-called ball is no bigger than a marble maybe that was why I tossed it into the drawer as soon as I tried to use it.  If Logitech bothered to make a REAL trackball device with a marble no bigger than 10cm (100mm) in diameter then I'll buy it/use it.
I suspect they only made that device for children because it's just too small for me to use.
Offline Badwrench
« Reply #25 on: Tue, 22 October 2013, 12:04:08 »
Problem solved  ;)
Yeah, it is a bit on the small side, but very comfortable in my small work area.  Just took a bit of dialing in with cursor speed.
Offline MTManiac
« Reply #26 on: Thu, 24 October 2013, 11:21:40 »
I am a big fan of goliath mouse pads
If you want a 'semi-office' oriented pad you should check these out
Plus you'd be supporting (imho) one of the best crowd sourced games to come out ever!
Star Citizen!
Link to store
The pads are 36.22” x 11.57”
Offline Emospence
« Reply #27 on: Thu, 24 October 2013, 11:52:47 »
I liek mai Artisan
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #28 on: Thu, 24 October 2013, 14:46:36 »
Any FUNC mousepad? :)
Offline UniClown
« Reply #29 on: Thu, 24 October 2013, 15:19:14 »
I can recommend the Steelseries Qck Heavy version. Has a very small logo in the corner, and is top quality cloth pad for the price.
Offline Oobly
« Reply #30 on: Fri, 25 October 2013, 02:31:09 »
Steelseries S&S is a good one. Hard plastic, nice texture, rubberised underside. I also have an SX (aluminium pad) but it can be noisy depending on the mouse used (Roccat pyra is quiet, RAT3 is noisier, Logitech G9 somewhere in between).
The mouse glides so smoothly over them both, I can't go back to a soft pad.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline ctbear
« Reply #31 on: Sun, 27 October 2013, 13:14:59 »
Agree with the Artisans. If the price is not a problem for you that is  ;D
Offline Emospence
« Reply #32 on: Sun, 27 October 2013, 20:17:52 »
Hien VE is very affordable if the textured surface does not disagree with you :)
Offline Elrick
  • Hype Master
« Reply #33 on: Sun, 27 October 2013, 21:02:38 »
So true, a hard surface is the most precise and quick compared to any cloth/material based mouse pad.
I tried to like using the Artisan but it just fails me completely.  The old Func 1030 still rules in my world and it's now very old, and still looks like new (the very day I bought it all those years ago).
