Author Topic: US to UK layout conversion?  (Read 13471 times)
Offline jawwwwsh
« on: Thu, 26 September 2013, 15:26:31 »
So for my 2nd mechanical keyboard I want a nice TKL board, and I'm looking at a Keycool 87 US layout online. It's MUCH cheaper for me to buy a US layout board than a UK one, and was wondering if anyone knows if it would be possible to re map keys, replace keycaps, change to a different language setting within Win7 and turn the US layout board into a UK one??
Offline Fragil1ty
  • Abre los ojos.
Re: US to UK layout conversion?
« Reply #1 on: Thu, 26 September 2013, 16:30:57 »
Not really sure why you'd want to do this, I find it much better to use / switch to the traditional US layout than convert it and what not.
But I'm assuming you just want  the @ to be where the " are and vice versa? I'm sure there are a few other symbols that are in different places such as the ~ and # but I'll let you sort that out.
To do it within Windows 7 it's rather simple, do the following:
Control Panel > Regions and Languages > Keyboards and Languages > Change Keyboards > General tab and just add / remove keyboards there and what not.
Pretty straight forward from there, good luck.
你搞砸了
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Thu, 26 September 2013, 16:34:52 »
You can plug an ansi board in and pretty much just type.  The " will be on the 2 key...The legends on the keys will be wrong, but i doubt that'll be much of an issue.  You'll lose the \ though, which is harder to deal with - I'd suggest using autohot key to remap the hash or something like that.
Offline jawwwwsh
« Reply #3 on: Thu, 26 September 2013, 16:38:13 »
The main reasons being the lack of a £ sign, and for something to do! The loss of \ wouldn't be acceptable though, I spent a lot of time in cmd & powershell so I guess I'll just buy the american one and not care about the layout :)
« Reply #4 on: Thu, 26 September 2013, 16:39:40 »
You can easily autohotkey the £ and \ to other keys or combinations.
Offline DamienG
    • DamienG
« Reply #5 on: Thu, 26 September 2013, 17:09:20 »
Moving symbols around is easy enough - just use the UK layout option on a US keyboard (in Windows).
The real problem is you are going to be one key short - by having " and £ on 2 and 3 you're going to need a key with # on it. These are normally next to return which is double height and the US |\ key going down next to Z.
The simplest option is to go with a US keyboard, set it to US and use autohotkey to put £ on 3 with right Alt key instead of shift. The config line for that is:
RAlt & 3::Send {£}
Hardware options involve cutting a hole, modifying the left shift stabilizer and figuring out a way to wire it up to the controller chip possibly replacing that with a Teensy. Which is crazy and assumes you can live with the wide return instead of the tall return...
[)amien
« Reply #6 on: Thu, 26 September 2013, 17:17:00 »
There is a topic of people who have converted a keyboard from ISO to ANSI, if you want to do the hardware as well. It's not impossible, but it does take some effort. Of course, some keyboards have mounting holes for ISO keys, you will just have to modify the plate to account for this.
http://deskthority.net/workshop-f7/iso-to-ansi-t155.html
@OP: I would recommend sticking with the (much better, in my opinion) ANSI layout, just remap some keys in software to get your pound sign, etc. You should be able to map right alt + 2 to be the pound sign if you need it, There are other tweaks as well. Autohotkey is a program for windows that looks good for this.
Offline oscillik
    • music podcasts
« Reply #7 on: Thu, 26 September 2013, 18:16:03 »
RAlt & 3::Send {£}
I've just tried this, but every time I try to use it, I keep getting £ instead of just £
Any ideas? I'm using a HHKB Pro 2 on Windows 8
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline DamienG
    • DamienG
« Reply #8 on: Thu, 26 September 2013, 18:25:02 »
It's probably the text config file being ANSI and not Unicode. You could change that or just instead use this encoding-safe version:
RAlt & 3::Send, {U+00a3}
Oh, and if you need the Euro alt-gr on 4:
RAlt & 4::Send, {U+20ac}
[)amien
« Last Edit: Thu, 26 September 2013, 18:28:27 by DamienG »
Offline oscillik
    • music podcasts
« Reply #9 on: Thu, 26 September 2013, 18:31:35 »
[)amien
You are a genius! Thank you! £€£€£€£€£€£€£€£
Offline jawwwwsh
« Reply #10 on: Fri, 27 September 2013, 05:22:03 »
Nice! Thanks for the replies, I'll try the key maps when I get home tonight! I'm going to be buying an ISO layout board later on today, and an torn between the CM Storm Quickfire Rapid with MX blacks (TKL version, if there is a non TKL) and the DK2108 Zero with MX Browns, anyone got personal experience/advice on either board? I'm going to be getting custom keycaps etc, so if one or the other uses unusual caps, then it's out :)
Offline DamienG
    • DamienG
« Reply #11 on: Fri, 27 September 2013, 14:54:27 »
Technically the browns are supposed to be more tactile but I can't feel it myself. The only difference I feel between the two is that brown is light and black are heavy.
[)amien
Offline ch_123
« Reply #12 on: Fri, 27 September 2013, 17:51:29 »
There is a topic of people who have converted a keyboard from ISO to ANSI.
For me it was the opposite - my keyboards (specifically, a Filco TKL and a Model F) converted me to ANSI.
Under Linux, there's the US International (Alt Gr Dead Keys) layout which allows me to enter € and $. There are also some unofficial Windows versions, a quick googling showed up the following but there are others around -
Link
